wtf is wrong now..isv/idle prob 16v
Discussion in 'Engines' started by pigbladder, Jun 12, 2004.
  1. pigbladder Forum Addict
    cambridge , uk
    ok my 16v kr idles even and EVERYTHING checks out timing,isv clean and buzzing,c/o blah blah
    thing is...if i drop the clutch at say 1800 revs it plumets to below normal idle and then picks itself up
    if i dip the clutch at higher revs its okay...it then drops fast to 1200 ish then settle to idle
    could the isv just be worn out? its done 150k ..ive seen new uns for 39 notes on ebay
  2. J a m e s Forum Member
    try cleaning the connectors going to the isv, and the three connectors that are on the block under the dizzy.
    also check the connect on the hall sender on the dizzy.
  3. pigbladder Forum Addict
    cambridge , uk
    all good conectors
    why would the hall sender affect the idle?
    can anyone look next time they drive their(properley running) car..if you dip the clutch at say 1500-1600 revs does it drop to 1200 then gently settle to 100 ish
  4. KeithMac Forum Junkie
    Kazakhstan
    Mine catches at 1800 and then falls to 1200 then 1000, only thing that caused mine to fall below 1000 was bad mixture and idle screw settings but you`ve already cheked that?
    Even idles fine with the kents in.
  5. fireheed Forum Member
    Aberdeenshire
    If you are looking for a working ISV then PM me.
    I've got one spare, thought mine was shafted, so bought a new one but problem existed, so it's fully functional. Doesn't look the best but it does it's job, just requires a new gasket.
    Cheers
  6. daviddd Forum Member
    Caithness, Scotland
    My 8 valve improved idle dramatically P when I cleaned inside the throttle body / idle screw - they were really crudded up....a long shot though...
  7. pigbladder Forum Addict
    cambridge , uk
    yeah mines all mint inside, maybe the base idle could be a tad higher
  8. KeithMac Forum Junkie
    Kazakhstan
    Try 1050 to 1100 rpm hot.
  9. Mad-scientist Forum Member
  10. oak_grun Forum Member
    mines does the same thing pigbladder!! f$king annying i know!!!
    i have new isv, which buzz's...co content fine....just cant work it out....let us know if u do manger to fix the problem
    thanks
