Hello all I am rebuilding the WUR on my MK2 16v as my fuel pressures are leading to a very lean engine. So far from what i can tell is the o ring under the diaphragm inside the WUR is flattened from years of use causeing the fuel pressure to be incorrect. I ordered a 15mm ID x 2mm circumference but that does not fit so have now ordered a 14.5 mm x 1.5mm to give that a go. I know a rebuild kit can be ordered from the states but at 38 for a few o rings it seems a bit steep. Does anyone know what the correct size of o ring should be for under the diaphragm ???? thanks
That`s a shame as he rebuilt and modified mine a few years ago. Try TSR, Retro Resus and Stealth Racing then ... given their history tuning KJet.
He was happy to refurb for me but i already have it apart and only need an o-ring, he was unable to supply me with the size required (it seems to be the worlds best kept secret)
http://www.ferrari400parts.com/catalog/ have a look in wur section I see kits listed for rebuild and prices are in euro
Nice find ! i have found the size now thanks, 14 x 2 , and after putting it all back together it turns out the WUR is not the issue so the search goes on. I now think i have located the fuel pressure problem to the primary fuel pressure regulator in the metering head, the o ring was perished. You can no longer buy a rebuild kit for this regulator from VW or anywhere, ferrari parts does not stock them either. If i can find all the correct sizes i may buy a bulk lot and offer them for sale so if anyone else needs to rebuild theirs they wont have to waste hours of their day searching the net !
looking at ETKA the 2 o'rings are 3.2x2.25 and 3.9x1.8. part number for the rebuild kit is 035198691, I found one here: http://trshop.audi.de/konakart/Sele...ategory=Accesoires&name=GASKET SET&model=0001 also found the bosch part number mooching at google images which is 3 437 010 046, worth phoning your local bosch specialist they may be able to source it for you
