XENONS HOW TO ?
Discussion in 'Miscellaneous Technical Queries' started by crad, Apr 15, 2004.
  1. crad New Member
    I WANT SOME XENONS ANY IDEAS HOW TO FIT THEM
    VAG PARTS HAVE THEM A LOT CHEAPER THAN MAIN DEALER.
  2. harry_the_cake Forum Junkie
    Antarctica
    There are legal requirements to fitting Xenons.
    You need to fit the self leveling system to the front and rear suspension.
    You also need the high power lense washers that fit in the bumper.
    Have a read of
    this document to see whats involved. (right click, save as)
  3. Valver Forum Member
    What about all the recent featured Mk2's etc with Xenons fitted...pretty sure they didn't have the self-levelling/washers fitted?....
  4. The Other Simon Forum Member
  5. AndyG
    AndyG Forum Member
    Worcestershire
    well there not legal then
    mine has the self leveling and high pressure wash on both of my cars
  6. altern8 Forum Junkie
    Cocos (Keeling) Islands
    how hard were they to fit jettaman
  7. Funkyfin2000 Forum Addict
    Stafford, United Kingdom
    when i get my rallye grill i wanna buy Andys off him.....
    just wander how much he would take for em though!
  8. AndyG
    AndyG Forum Member
    Worcestershire
    I used the whole loom from an audi TT and fabricated brackets to mount the sensors to the front and rear axles
  9. AndyG
    AndyG Forum Member
    Worcestershire
    Well I sold my original xenon rallye headlights for around 450 to a guy in the States
    I've now got Bi-Xenon's fitted which are xenons in high and low beam
  10. Funkyfin2000 Forum Addict
    feck, il start saving dude.......
    need to get a rallye front end set up first.... then get you to fit the xenon set up! [:D] [:D]
    Edited by: Funkyfin2000
  11. Guests Banned
    XENONDEPOTUK AS FOUND ON EBAY AND JUST BUY 6000K HEADLIGHT BULBS. I INSTALLED A SET IN MY OLD E30 BEEMER AND THEY DIDNT HALF LIGHT UP THE ROAD. COST 10 QUID INC P/P FROM CANADA
  12. The Other Simon Forum Member
    If you really mean that you have just gone and bought some conventional halogen headlight bulbs with a bit of Xenon added, then you really need to read the Autocar product test.
    The only bulbs that passed their high brightness tests were the Philips VisionPlus and Osram SilverStar. The Osram ones can be bought for 12 on e-bay.
    Also bear in mind that bulbs that claim to have a colour temperature of 6000K are really bad in the fog (too much blue in the beam).
    Simon.
  13. VR6Will Forum Member
    i have the osram silverstar bulbs and find them probably the best bulbs ive had so far,
  14. VDub Lady Forum Member
    on my dads ex BMW he wanted xenons but there was a big problem to do with the power and battery etc so they were neva fitted!
  15. AndyG
    AndyG Forum Member
    Worcestershire
    also blue tinted lamps give crap light output, worse than any standard clear halogen lamp.
    I wouldn't touch them with a bargepole, load of junk
  16. Madbloke Forum Member
    Funkyfin ------
    For the Golf Rallyes you should be able to pick up a set of TT lamps and loom for around 200 - 250.
    Make sure you get the ballast and starter pack -- cant remember if they are built into the lamp unit or not
    In a nut shell the aim is to sw*p the parabolic reflector inside the rallye lamp with the TT one (think passat ones may also fit) You'll need to fabricate a bit to get the tt reflector to fit and a bit of cutting for the loom to plug into it from the back of the light.
    Also wire the lights so that the dipped beam stays on when using full beam otherwise you'll have periods of darkness when switching from full beam to main as the xenon unit takes a second or 2 to power up.
    With a mk4 youll just sw*p the whole unit ---- depends how fussy the mot man is as to whether he would pass it without power wash and sensors etc ;)
  17. AndyG
    AndyG Forum Member
    Worcestershire
    the Bosch system comes as 2 seperate units, ignighter and ballast, the hella system is better as it comes as 1 whole unit and so is smaller and easier to mount to the headlight
