Setting up a PC for a relative, and trying to update to SP2, but the keygen I have will not let me install the update(even though it worked on mine when SP2 came out ) Has anyone got a working key for XP Pro Corp,as I need to sort this pewter out asap...if so PM me, THANKS! Edited by: VeedubyaGTi
you wont get a Key as such from anyone, keys only work with 1 copy, its programmed into it. as you have XP pro corp im guessing its pirate. MS can tell which versions of corp have been leaked, if you had luck last time it may be because MS didnt know it was a leaked copy etc, and blocked it. the only way around this is to either get a cracked version of SP2 or crack your version of XP, its not the easiest thing to do tho
