Your Yearly Dementia Test It's that time of year to take our annual senior citizen test. Exercise of the brain is as important as exercise of the muscles. As we grow older, it's important to keep mentally alert. If you don't use it, you lose it! Below is a very private way to gauge your loss or non-loss of intelligence. Take the test presented here to determine if you're losing it or not. The spaces below are so you don't see the answers until you've made your answer. OK, relax, clear your mind and begin. 1. What do you put in a toaster? Answer: 'bread.' If you said 'toast,' give up now and do something else. Try not to hurt yourself. If you said, bread, go to Question 2. 2. Sa y ' silk' five times. Now spell 'silk.' What do cows drink? Answer: Cows drink water. If you said 'milk,' don't attempt the next question.. Your brain is over-stressed and may even overheat. Content yourself with reading a more appropriate literature such as Auto World. However, if you said 'water', proceed to question 3. 3. If a red house is made from red bricks and a blue house is made from blue bricks and a pink house is made from pink bricks and a black house is made from black bricks, what is a green house made from? Answer: Greenhouses are made from glass. If you said 'green bricks,' why are you still reading these???If you said 'glass,' go on to Question 4. 4. It's twenty years ago, and a plane is flying at 20,000 feet over Germany (If you will recall, Germany at the time was politically divided into West Germany and East Germany .) Anyway, during the flight, two engines fail. The pilot, realizing that the last remaining engine is also failing, decides on a crash landing procedure. Unfortunately the engine fails before he can do so and the plane fatally crashes smack in the middle of 'no man's land' between East Germany and West Germany . Where would you bury the survivors? East Germany , West Germany , or no man's land'? Answer: You don't bury survivors. If you said ANYTHING else, you're a dunce and you must stop. If you said, 'You don't bury survivors', proceed to the next question. 5. Without using a calculator. You are driving a bus from London to Milford Haven in Wales . In London, 17 people get on the bus. In Reading, six people get off the bus and nine people get on. In Swindon, two people get off and four g et on. In Cardiff, 1 people get off and 16 people get on. In Swansea, three people get off and five people get on In Carmathen, six people get off and three get on. You then arrive at Milford Haven. What was the name of the bus driver? Answer: Oh, for crying out loud! Don't you remember your own name? It was YOU!!
The green house one is stupid, and although I immediately thought glass, if you had houses made from pink, blue or black bricks, then surely it would be reasonable to assume that you could have one made of green bricks.
Agree with Rallye Will - I was following the brick logic. Pretty much crashed at every other question tho
Yep got them all but the greenhouse one, as i'd heard them before. But yeah the greenhouse one is a big fat meanie
Greenhouse effect! It's true that a greenhouse is made of glass, or perspex or similar translucent material... But a green house (note the space) would / could be made of green bricks...
