2.0L 16V FSI Head Design
Discussion in 'FSI (inc. GTI 2.0T)' started by Brookster, Sep 17, 2010.
Tags:
  1. HPR
    HPR Administrator Admin
    Recently flow tested an ex works BTCC head
    Test with 84 mm bore
    inlet with plasticene roll entry
    inlet valve 34.9 mm
    CFM @ 10`` H2O
    2 mm 35,6 / -1,1% against STD head with STD 33.9 Valves
    3 mm 51,3 / -5,2
    4 mm 67,6 / -4,9
    5 mm 84,0 / -2,3
    6 mm 99,5 / - 0,7
    7 mm 113,6 / - 0,3
    8 mm 126,5 / + 1,0
    9 mm 137,6 / +2,6
    10 mm 146,7 / +6,0
    11 mm 154,3 / +9,7
    12 mm 160,7 / +12,1
    13 mm 164,9 / 14,0
    14 mm 168,7 / 15,9
    15 mm 171,5 / 17,1
    exhaust valve 29,0 mm
    2 mm 34,1 / + 1,5 against STD head with STD 28,0 mm Valves
    3 mm 51,9 / + 1,2
    4 mm 62,7 / - 6,0
    5 mm 71,3 / - 8,8
    6 mm 77,5 / - 9,4
    7 mm 82.6 / - 7,8
    8 mm 87,1 / - 5.2
    9 mm 91,0 / - 2,7
    10 mm 94,0 / - 0,7
    11 mm 96,4 / + 0,8
    12 mm 98,2 / + 1,2
    13 mm 99,8 / + 2,7
    14 mm 101,1 / + 3,6
    15 mm 102,2 / + 4,2
    the head has some sharp edges in the ports and in combustion chambers around the valves
    the owner copied the head and made some improvements and found + 25 hp
    ( head + new mapping )
  2. R.b!n_16v Forum Member
    is that from a early vw 2l 16v or the fsi>?
  3. HPR
    FSI Heads , otherwise it would be in the 16V forum
  4. R.b!n_16v Forum Member
    nicee.. do you got any pics of the head? im curious
  5. HPR
    Seat Toledo /Leon S2000 > WTCC/BTCC ( before they went TDI )
    VW POLO S2000 > IRC
    SKODA FABIA S2000 > IRC
    VW F3 engine
    All these use the N.A FSI engine as basis , its all in this tread
  6. Brookster
    M1 J40
    Pix from Page 1 of this thread. :thumbup:
  7. MNZ
    MNZ Forum Member
    Is there any reason a whole alloy blocked FSi can't be used. Is that the reason we are talking about mounting the heads on older blocks?
    Could an alloy engine not have new pistons fitted without the swirl chambers and then port injection etc?
  8. HPR
    Both alloy and steel blocks can be used.
    Alloy blocks are relativ new to us and we dont know yet where the limit is on these...
    Many have already older type steel block engines, and by dropping a set pistons in and change the head, can make serious power as the STD head flows already very well.
    With pistons similar as in post 44, ITB / port injected, it should work well
  9. R.b!n_16v Forum Member
    Looks good:thumbup:
  10. Brookster
    M1 J40
    i was at AET Turbo's yesterday and met Ronald Winters who runs in the Dutch Timeattack series.
    He runs a MK1 TFSI on Megasquirt management. very interesting MK1 I'll post some pictures later.
    Also found out that the TSFI has MAHLE Forged pistons fitted from the factory.
  11. brutalmk2-16v Forum Member
    Manchester
    Has anyone got a clue how much would a second hand head go for?
  12. Brookster
    M1 J40
    200
  13. brutalmk2-16v Forum Member
    Manchester
    Hm.. I'm looking in etka the part numbers 06F 103 285 and 06F 103 373 to confirm a head but it says there is not such part number.I'm i doing anything wrong? can anyone confirm?
  14. Brookster
    M1 J40
    i need the ETKA software , were do you get it from
    cheers
    F3 info appeared to be a bit of a side topic to this thread, so now shifted to here
  16. Tristan
    woukd the FSI block bolt to a "classic" VAg box , eg 020, 02A etc?
  17. HPR
    Yes, 020, 02A, 02M all fit
    IMO its the same alloy block as used in the ALT 20V
    its just an evolution from 06A blocks
  18. Tristan
    Thank you for that.
  19. mec82 Forum Member
    very interesting indeed...
    So assuming you guys manage to physically mate up the head onto an ABF/9a/KR, whats the situation regarding ancilleries, mainly thinking exhaust manifold?
  20. Tristan
    why use the ABF block , instead of the alloy block , or standard mk5 one?
