2.0L 16V FSI Head Design
Discussion in 'FSI (inc. GTI 2.0T)' started by Brookster, Sep 17, 2010.
Tags:
  1. mec82 Forum Member
    I think you're right the alloy block would be a better option but I think its just that the steel blocks are well known and reliable blocks and readily available. I may be wrong but I think the small block alloy units at least have some issues with warping when disassembled?
  2. Dave R
    Dave R Forum Member
    Rhondda
    I'm currently having my bottom end rebuilt. Wish I went for a FSi lump now... Most interesting read I've seen for a while. 290+bhp N/A, I just wet myself thinking about it
  3. Igor Forum Member
    amazing thread, this is what I was looking for years, finally proper design of VW FSI head for N/A.
    Look very similar to my racing honda S2000 f20 head, and pretty close to old Graf 16v.
  4. HPR
    HPR Administrator Admin
    Pistons are for port injection ( classic pentroof type )
  5. veenh386 New Member
    Goodday
    I am new here. Read all off this thread and i want to share the building of my alloy fsi engine whit you.
    How can i get picture's into the message
  6. danster Forum Addict
    ^^^ PMed.
  7. brutalmk2-16v Forum Member
    Manchester
    Goodday to you too.
    Would be very interested to see.
    Welcome to the forum btw :thumbup:
  8. lewp91 Forum Member
    Hertfordshire, United Kingdom
    photobucket.com
  9. brutalmk2-16v Forum Member
    Manchester
    Damn, due to the excitement i failed to answer to question lol
  10. RMN
    rmn Forum Member
    I have toally missed this thread, dont know how, but its a really good read.
    On the pistons, i take it that due to the direct injection of the FSI system the pistons must be changed for conventional design to maximase airflow in the combustion chamber?
    Has anybody used the alloy block?
    It has to be worth a go due to the 20kg weight advantage of using it!
    I sware by ABF motors, but this makes me think....
  11. lewp91 Forum Member
    i concur regards to missing and reading this thread :p once cleaned up i believe it deserves a sticky status ;)
  12. veenh386 New Member
    Goodday.
    I am new here and i am building an fsi engine..
    Pictures say more than words
    more picture's will follow. I am now making the dry sump kit and main bearing gradle. From a tfsi did not fit an aluminium engine.
  13. idrivemyself New Member
    Washington, USA
    ^Very nice. Did you make a complete plug insert for the injector holes or did you just patch over each port?
  14. TonyB Paid Member Paid Member
    Ammanford, Wales
    Very nice. I'm in the process of getting the base parts ready to build an FSi for my race car. I have to use an early 1800 block due to regs so slightly more difficult hence quite a bit of reasearch first [:^(] Hugo (HPR) has quite a file of info on these engines and many parts.
    I'm interested in the welding (I assume its welded) on the ports, the injector holes and chambers. What process did you use and how did you avoid warping/distortion etc.
    Standard valve sizes? What rocker system? Who's/what cams, Who's manifold?
    Sorry lots of questions but you know what it's like [:$]
  15. veenh386 New Member
    I make plugs for the injector hole's and weld then. put the cilinderhead in a oven weld and put it back in the oven and let it cool down for a day. You can see it in the picture differnt colour of the aluminium. Manifold is cutom made out a billet of aluminium So alllso will be the dry sump caps. Ready on two or three weeks.
    I make the rocker systeem mechanical.necessary for the cam schaft. I get one from a vw polo S2000
  16. Tristan
    any more info on this? Just wondering what FSI heads work best?
  17. Tristan
    Ta for that.
  18. veenh386 New Member
    Goodday,
    Here are more picture's of my engine. Must now finish my cilinderhaed. Make it mechanical en adjust the valve.
    http://www.mijnalbum.nl/index.php?m=fto&a=73&id=279494851&key=4BJNAJGE
    http://www.mijnalbum.nl/index.php?m=fto&a=73&id=289632465&key=7TBXKXJK
    http://www.mijnalbum.nl/index.php?m=fto&a=73&id=279494616&key=HY6UAIHB
    Some parts of the dry sump are ready. The aluminium pully is anodiseerd whit nituff. Thats why the colour is grey. But it is very hard.
    More picture's in the future.
  19. VWtuner-NL New Member
    Do you got any pics from this BTCC head?
    Greetings,
    Martijn.
  20. Tristan
    keep up the good work! any more photos?
