'89 Golf Mk2 TDi Build Thread
Discussion in 'Mk2' started by DN5, Apr 11, 2016.
  1. DN5
    DN5 Paid Member Paid Member
    Doncaster
    Jesus - could be anything lol
    I'm not worried but it'll be interesting to see.
  2. DN5
    Doncaster
    These two are all i have hooked up for the obd socket. Top wire from immobiliser box that I no longer need as de immobilized ecu and bottom wire direct from obd socket.
    I have no more diagnostics wiring I can see. Is this all!?
  3. m1keh Forum Member
    You need a +12v and two grounds if you ever want to use vag-com
  4. DN5
    Doncaster
    Sorry, I didn't mention that part, i hooked up the other 2 wires from the plug to cig lighter. +12v and earth.
    Im just astounded that vcds can operate through so few cables!
  5. m1keh Forum Member
    If you want some fun bedtime reading the KWP2000 is the protocol used for serial communication down a single wire.
  6. DN5
    Doncaster
    Had a read and didn't know that was possible lol thought I'd missed half a dozen wires! Educated!
  7. DN5
    Doncaster
    Feeling the cold :(
  8. Cat88 Forum Member
    Manchester, UK
    Looks stunning mate
  9. DN5
    Doncaster
    It's getting there thanks buddy. How is your resto/daily coming on?
  10. DN5
    Doncaster
    My rear bumper had a snapped guide and would poke out on the drivers side. I bought a new guide but the original one was plastic welded into the bumper. Here's how I swapped it...
    Cut the broken one into quarters...
    Ideally using a mini blow torch like used in the kitchen or just a powerful lighter - heat up the ball of plastic and twist off the piece of guide...
    Repeat for all 4 pieces and test fit the new guide.
    Then again warm up the plastic 'nubs' and flatten onto the guide face and insert self tapper to each corner...
    New plastic slider fitted both sides...
    Fits perfect now and looks fresh and straight!
    Took 30 mins max [8D]
  11. DN5
    Doncaster
    New Darkside rear mount fitted in prep for the Garrett turbo
    It is apparent after test fitting the turbo that I'll need to chop the rubber mount so new one bought (even though it's going to be cut up lol)
    Original vs Upgrade
    Doesn't look so big but it's a fair upgrade!
  12. DN5
    Doncaster
    Found the turbo (gt1749vb) on eBay for 125.
    Only had slight play in the shaft but gave it a quick rebuild as its on the bench anyway.
    Stripped down and the vanes looking sooted up...
    Gave the VNT and the housing a soak in jizer over night and it came out looking brand new! Top stuff for cleaning.
    And refitted...
    New CHRA sourced and fitted. Already balanced...
    New Garrett actuator fitted for good measure...
    I set the actuator up using a vacuum hand gun pump with pressure gauge. Once I can road test, this can be adjusted if necessary.
    Just waiting for the weather to warm up so I can go fit it and fit the 2.5" Darkside downpipe [:D]
  13. Cat88 Forum Member
    Manchester, UK
    Coming on slowly but surely, weather looks like it's improving so I've got some small jobs planned for tomorrow. Updates to follow :thumbup:
  14. DN5
    Doncaster
    Nice. I'll keep an eye on the thread. Good work mate
  15. DN5
    Doncaster
    Won this on eBay for 160 so happy with it and now I am missing nothing to finish this project [:D]
    Will need a few repairs and eventually a retrim. Cannot wait to drive to the MOT station lol
  16. DN5
    Doncaster
    Can anyone recommend a solution for the intake air temperature sensor?
    The current one is located within the stock plastic boost pipe but I won't be using this.
    Is there something suitable out there that can be used and just wired into my existing loom? Read a few things on here but nothing of help.
    Thanks, Rich.
  17. DN5
    Doncaster
    Would it be possible to get a iat and map all in one? That i can fit into a custom intercooler pipe? That would save a whole lot of messing!
    Edit * found one at dark side developments with the wiring that solves both inlet temp and map issues that I've been trying to solve.
    Job done!
  18. Spacecowboy Paid Member Paid Member
    West Mids
    Nice paint job. Was it done local to you?
  19. DN5
    Doncaster
    Really happy with the paint. Yes, the place is about 3 miles from me and he has the local contract for Mercedes work so can be busy with other stuff.
    It's in Doncaster, where are you located?
  20. Spacecowboy Paid Member Paid Member
    West Mids
    I'm Worcestershire based. I have a few good options around here that I will investigate over the next few weeks. Primarily I want the bonnet painted and one wing replaced and painted so in all honesty I suspect I'll end up painting the entire front end but then the rest of the car won't look as good... hmmm...
