New M10 alternator Adjustable Turnbuckle fitted GRP Bonnet for the 2015 Season ready for paint (Lhasa Green) 38mm Vents drilled to prevent heat soak and aid TB Air flow.
The time has come to upgrade the gearbox so my beloved 020 Box is up for sale. Great box served me very well http://www.clubgti.com/showthread.p...fe-LSD-Sachs-Sporting-Clutch-Lighten-Flywheel My Great 020 ACD Code Gearbox 3.94 Final Drive Fitted Quaife Limited Slip Diff Ratios - 1st 3.45 , 2nd 2.12 , 3rd 1.44, 4th 1.13, 5th 0.89 100mm Drive Flanges Sachs Sporting Pressure Plate Helix Ceramic 4 puk friction plate Lighten & Balanced Flywheel Modified Flywheel SACHS Heavy Duty Pressure plate for the Helix Ceramic 4 PUK Sachs HD pressure plate, Helix 4 Puk ceramic paddle and lightened Hotgolf Flywheel. 020 Gearbox 3.94 final drive & Quaiffe LSD , TSR Linages, short shift & weighted shift ready to go in too. I'm upgrading to an 02J DZL V5 Box with 4 Pot bell housing fitted and Gripper Diff , i'll keep you posted on progress
Got the new Gearbox 02J - DZL Bora V5 BOX so need to change the Bell House Casing for a 4 pot one . The Ratio's are spot on though so worth the extra work Final Drive - 3.94 1st - 3.30 2nd - 1.944 3nd - 1.308 4th - 1.029 5th - 0.87 (won't be using on the strip) Also got a New Quaife Diff on the Way
Update - Gearbox all rebuilt final spec - DZL internals , Peloquin's LSD , ARP Diff bolts Final Drive - 3.94 1st - 3.30 2nd - 1.944 3nd - 1.308 4th - 1.029 5th - 0.87 clutch release fork modified with welded in plates 5kg Hotgolf Lightened Flywheel 6 PUK Clutch plate Peloquin's Diff 02A Casing Fitted The finished Gearbox ready for fitting Tonight cable clutch release fitted and Rod Change gear system for the 02A/02J
Why did you fit the 02a casing to the 02j? Interested as my dad is hoping to fit a 02j to his mk1 16v.
The 02J was a DZL Code from a Bora V5 ( Different bell housing on V5 & VR6 ) The DZL Ratio's were exactly what I wanted.
Ok understand. We have sourced a 02j from a non turbo 20v a3 which has given us the ratios we need. Sorry for the questions. I think iv missed it but what gearbox mounts did you use? What drive shafts/CV/hub/upright have you used? (I assume 100mm stuff?) What shifter? Hydraulic clutch conversion? Is that an off that shelf clutch?
02A 100mm flanges Cable Clutch Actuator (SEAT) from Holland https://www.bolt-action.nl/product/vw-02a-cable-clutch-actuator/ Bolt Action 02A Rod Change Conversion from Holland https://www.bolt-action.nl/product/mk1-02a-cable-to-rod-shift-conversion-stainless-steel/ XKD Stage 3 6 PUK clutch from USA EPYTEC Engine Mounts https://www.bolt-action.nl/product/vw-mk1-02a-gearbox-mounts/
My Friend James Hodson uses the Peloquin's Diff and has had great results over the last 7 years so that made me decide on this types my Gearbox man did comment and was impressed with the diff and the ARP bolt's I supplied for fitting . I was thinking of going for the Gripper plate diff at one point but didn't know anybody using one .
Gearbox all fitted , I also made a modification to the Rod Shift Kit were the linkages connects to the vertical movement pivot . the original bolted straight to the OEM Bracket but the shift was stiff . As you can see I have added a extended section which gives more leverage and a smoother shift . The rod shift is all complete and the shift is very smooth and direct.
Update - Clutch cable was too short , thought it was too much of a struggle to get it on. so extended it with an M6 Rod coupler and 2 locking nuts. Extended works perfect total cost (25p) All finished
Update - Everything is ready for the 2015 season but now looking further forward and the Turbo Project is starting to gather speed . Looking for a manufacturer of a Tubular Manifold with top mounted T4 Twin scroll twin 38mm Waste gate Flanges. The Turbo Engine will be the same capacity 2036cc 16v with lower compression 8.5 : 1 JE Pistons 20v Turbo Inlet manifold custom made same as Toytec's to a 16v bottom flange. final spec has to be finalised but will also be looking at the following . Megasquirt MS1 V3 Coil on Plug Coil packs RC 1000cc injectors
Update Drove the MK1 for first time with new Gearbox set up , the engine feels a lot better balanced with the 02J and lightened 228mm flywheel compared to the old 020 set up. Also updated the Megasquirt software on my tablet , very impressed with the update and works great with the Bluetooth dongle just waiting for Fibreglass bonnet and tailgate back from paint shop
