MK1 GTI 1.8T 20v 25 Year Project
Discussion in 'Members Gallery' started by Brookster, Jan 4, 2009.
  1. Brookster
    M1 J40
  2. Brookster
    M1 J40
    Ok winter upgrades underway
    ABF Ribbed belt alternator set up
    does anyone have the part number for the Crank pulley with no other pulley attached ( single )
    plus has anyone got a spare spacer bolt for top right hand of the alternator bracket
    Mr Pinder you'll have loads of spares ;)
  3. Brookster
    M1 J40
    New clutch was fitted for GTI Festival last event of the year and did a few NASP PB's
    13.31 sec @ 100mph 1.77 60/ft
  4. Brookster
    M1 J40
    Old clutch lasted 2 seasons of abuse
    will change every season now , 2 was too much :thumbup:
    clutch release fork strengthened a few years ago
    All done :)
  5. Brookster
    M1 J40
    New fuel pump upgrade too
    Bosch 044 and also increased the fuel pipe from the tank to 12mm ID ( was 8mm ID)
    1.8T_mk2 likes this.
    the mk3 v-belt pulley should split off from the ribbed one, they can be a bit stuck tho :) but the abf crank pulley is 037105243B, good luck finding one for reasonable money though!
  7. Brookster
    M1 J40
    Nice one cheers i'll have a look to see if i can split it when it comes out of the dishwasher with the other parts ( don't tell the wife )
  8. rubjonny
    I wont if you wont tell mine about the time i used it to clean out my washer bottle :lol:
    I've been thinking about getting a wee desktop one just for parts washing, but trouble is got nowhere to put it!
  9. Brookster
    M1 J40
    Split it , sorted cheers
    Nige and rubjonny like this.
  10. Nige
    Nige Paid Member Paid Member
    I gave the spare Pulley I had to Tom (Smudge) a couple of months ago. I don`t have another :(
    Brookster likes this.
  11. Brookster
    M1 J40
    All sorted now and fitted don't how i put up with the old v belt set up for so long .
    abit tight on the tensioner side so had tocounter sink the pulley bolt .
    does anyone have the part number for the M8 spacer bolt for the back of the alternator bracket ?
    I have another kit with only that part missing
  12. Brookster
    M1 J40
    Update - I killed No 4 cylinder
    well after 8 years the engine let a valve go on no 4 cylinder inlet , i actually completed the race on 3 cylinders and did a 15.4 sec @ 80mph ( valve went just after 60ft )
    so back to the drawing board and decide on the future spec for the 16valver , i was aiming for a 12.98 1/4 mile NASP with the new gearbox ratios . clutch and i finally converted to cable shifter set up.
    not too much damage to the bore so should be ok with a Hone , problem is i cannot get 1 replacement JE Piston as they are custom made pistons
    so future plan is to go NASP Only and try for the 12.98 sec 1/4 with 200bhp
  13. Sirguydo
    Bolton
    What's special about the JE Pistons ? Sure Nige is running standard ABF Pistons and I know they're good for well past 200 bhp .
  14. Nige
    Damn [:x]
    As you know, I had exactly the same failure and that destroyed my block too ! You were luckier than me in that respect.
  15. vw_singh Events Team Paid Member
    Custom compression ratios Mike. Easy to buy pistons with the required CR and have things like deeper valve pockets and correct squish band without risking failure of a machined OEM piston.
    Sorry to see this Brookie. Hope you get it sorted soon.
    Do you know what caused the valve head to drop off or was it a random failure? Brand of valve?
    Gurds
    Brookster and Sirguydo like this.
  16. Greigzy Forum Member
    Have read through this over the past week on my lunch break. Have really enjoyed reading about the journey and progress you have made. Would love to build a similar spec engine for my car too :).
  17. Brookster
    M1 J40
    Missed the gears and few times on the Saturday due to new box and cable shift set up issues and hit max rpm i think , the valve snapped off the end of the stem .
    they have been in 8 years so had a good run out of them.
  18. vw_singh Events Team Paid Member
    Fair play. 8 years is going well for a race engine.
    Gurds
  19. Brookster
    M1 J40
    Just looking at the spec options for the new rebuild -
    Wilder race cams
    Higher compression
    Bigger injectors
    Mapped on Race Fuel
    220 - 230 bhp target power
    Toyotec, sparrow and Sirguydo like this.
  20. Brookster
    M1 J40
    Options -
    The 16v will be getting rebuilt but also looking at options to make do in the meantime ;)
    Here's some food for thought
    2.0L 20V ALT Block weight compared to the 16v ABF Block
    ABF 16V - 42.8KG
    2.0L 20V ALT Alloy block 19.4KG
    oh look what i found a low mileage 2.0L 20V ALT Engine , i wonder what power that will push out with 45mm ITB's bolted onto it ? 24kg lighter must be worth 10bhp and we can always put more Nitros through it :thumbup:
