VCDS ABF measuring blocks
Discussion in 'Vagcom / VCDS' started by Matas, Aug 4, 2020.
  1. Matas Forum Member
    Anyone can help me with ABF measuring blocks? Which groups I should give attention the most, what numbers I should see to know if sensors are working properly?
  3. Matas Forum Member
    ok well the main ones are coolant and inlet temps, throttle position and engine speed. you can check idle switch also in the 1st block under 'adjustment conditions' or the far right block 8 digits. hover over and it will tell you what each digit means.
    lambda is next one, check voltage fluctuates as it should etc. as I say, not a whole lot in there either 5 or 7 blocks depending on ecu age
  5. Matas Forum Member
    IMG_20200806_152239.jpg IMG_20200806_152210.jpg IMG_20200806_152137.jpg IMG_20200806_152110.jpg IMG_20200806_152033.jpg IMG_20200806_152001.jpg
  6. its broke again New Member
    Hmm how do I access the label files? When I click on the link it says I don’t have permission?
  7. rubjonny
    you need to get a few more posts to get your account confirmed, then you can get it :)
  8. its broke again New Member
    Ah makes sense
    Thought ide got passsd that
    No worries
