8v Appreciation Society Busted!
Discussion in 'General Chat' started by danster, Jun 19, 2010.
8AS Membership vote - Danster
  1. Do we keep Dan/Danster in & let him off for his drunken comment?
    56.3%
  2. Kick him out & leave him with the 'People's Front for More Valves' lot?
    43.7%
  1. madasafish100
    madasafish100 Forum Member
    Trowbridge
    Brand spanking new, in parts and labour etc it's worth more than that by a fair bit, but now I wouldn't expect to get that much no.
    I only put that as a figure cos I "had" to to stick to the rules and not what I know I could get. It was a safe figure basically :)
  2. Zaphod
    Zaphod Forum Member
    Wantage
    The only good 16v motors have half the number of cylinders..
  3. danster Forum Addict
    Bump for results. [:s]
  4. A.N. Other Banned after significant club disruption Dec 5th 2
    Still inconclusive, especially after 24 hours in which the Green Machine may not recieve the quality of 8v engine it has been getting thirsty for. Heaven forbid a 16v will be used as the easy option!
    To torment a poor fat Mk2 Scirocco like that is not what the 8AS expects from its leader! :lol:
  5. danster Forum Addict
    Green rocco has an 8v installed. :thumbup:
    Results for election in yet? I reckon Gaddafi will be out on his butt before we get a result in this sham vote. :lol:
  7. danster Forum Addict
    At least members of the 8vAS actually bother to help out their fellow dubbers regardless of valve class or status.
    It certainly seems a one way flow when the only thing coming back the 8vAS's way is more unjust propaganda from the deluded PFFMV.
    All well and good! But where is the 8AS challenge for the 16v RR day?
    No interest at all !
  9. danster Forum Addict
    [:s] Eh, it is a 16v rolling road day? This suggest no 8v cars are allowed. (in case they show you up)
    Have you been out in the sun too long? :lol::lol:
  10. Dave
    Sligo, Eire
    They obviously read the wrong threads Danny![:s]
    Power alone does not maketh the car!
    There are so many more attributes, related to THE GTI, which only has the 8v motor, as noted elsewhere, quite recently!
    Pfft, shoot (out) first, ask questions later :lol:
  12. danster Forum Addict
    Poor 16v engine. Tuned by danster!! :o
  13. StuMc
    50? 20` 47 N - 06? 57` 57 E
    No wonder Glen is having compression issues... :lol:
  14. Admin Guest
    worried about compression?
    i'd be concerned at the oil consumption that could rival a Ford!
  15. Toyotec
    Pfft ...even on 3.459 cylinders it still had more power that most modified 8vs.
    Putting a hatchet to a 16v will only make it equal to an 8v [:D].
  16. bobski Forum Member
    Scotland
    obscene pictures of engines being hacked to death....you deserve a 8v danny:lol:
  18. danster Forum Addict
    Iz it results time yet? I am nearly at retirement age. [:s]
  19. motha Forum Member
    The Convict Island
    I've read been trawling through this & the other 8v hating threads & having a bit of a laugh about it all.
    Just for interest sake, the 2nd fastest "FWD" VWon the planet are yep, you guessed it
    8V headed 4cyl.!!!!!!!!!!!!!
    & to rub it in even further!!! Its still a counter flow 8v head!
    So laugh away cause the 16v's don't come close to this.
    Fastest FWD VW is a 20v that I can find. 8.765
    The 3rd is a 16v, which is 2 plus tenths behind the 8V! haha
    VW AP2000 83.5mm x 92.8mm
    Head:OHC 08 valves non-cross-flow (intake and exhaust in the same side), port and polish by Pro-heads
    Cams: Sans Cams 296 degrees (9k rpm rev limit)
    Springs and retainers: Crane
    valves: 40mm intake and 35mm exhaust
    Turbo: Garret GT4088R
    Header: German (custom)
    Intake: Belquip (custom)
    Pistons: Iapel 83.5mm 8.5 CR
    Rods: Howards
    Crankshaft: OEM 92.8mm
    Flywheel: Sapinho (custom)
    Clutch: Multi disk by Barpan Argentina
    Injectors: 8 x Bosch 160lbs/h
    Fuel Pump: Weldon 2345D
    Fuel Pressure Regulator: 2 x Fiat Tempra
    Distribuitor, cables: MSD
    Ignition and Fuel controller by HIS PW6X
    Suspension: Impacto
    Traction bars: Sapinho (custom)
    Icecooler: Supercooler - the system is cold by the methanol.
    Gears and spool: Forged and made by Sapinho
    Booster: the car stars w/ 20psi, go to 35psi and finish with 43,4psi
    [YOUTUBE]usWSifOdvA4[/YOUTUBE]
    PS. There is a full chassis'd corrado running 7's with a 16v! Full chassis meaning full race car, race trans, full house 9" rear diff etc etc. So the only part of the corrado is the taillights probably! So the only thing that is VW is the engine & badge.
  20. Admin Guest
    The hate is just banter, i once owned a few 8v's and loved them to pieces but, then i had a vision and saw the light, since joing the church for the PFMV i have never looked back. :lol: Bring on the next service, maybe we could let a couple of the better 8AS members in just for the morning?
