Challenge Accepted......
Discussion in 'Members Gallery' started by foxyjay, Sep 28, 2014.
  1. foxyjay Forum Member
    I'll take any kind of compliment - even heavily veiled, back handed ones! lol
  2. benthejettaman Forum Member
    some where in the uk
    love to see this progress
  3. foxyjay Forum Member
    Had the day to myself so decided to push on with the project and see what I could progress -
    Got the Mk2 dash out and found it in worse condition than I thought due to sun cracking top plastic.
    Fortunately I kept a mint dash out of a 16v I broke, just for this occasion :)
    Pedal box ready to extract
    Wiring mostly unplugged and removed
    Dash looking sorry - and pile of spaghetti...
    Pedal box out
    Octavia dash removed although all critical wiring left intact for now.
    I want to be able to test and run this car right up until the last minute before the engine gets pulled.
    I tried the Octavia pedal box in the location where the golf's fits and it's clear the Octavia unit would fit exactly had it not been too tall.
    The crafty VAG group have not really changed *that* many basic concepts if you look under the skin of these cars.
    The brake servo hole and bolt PCD are same - albeit two fixing bolts these days, not the four.
    I'm going to have to use a Mk2 pedal box and adapt it to fit the Octavia brake pedal - Luckily they haven't changed the relative pivot point all these years, either!
    The throttle pedal (no pedantic splitting hairs please - I know it's not a throttle! :) ) - will be electronic as per the Octavia.
    However, I don't want to mount it on the floor - which means *not* using the stock Octy pedal.
    I have a 2010 Touareg pedal which mounts from above - I will make an adapter loom and try it to make sure it's going to give required same signal to the ECU.
    If so, I will just need to hope there's space for it and then make a bracket.
  4. foxyjay Forum Member
    Where it all happens...
  5. afbiker02
    Bury St. Edmunds
    I love that your doing something different, keep it up.
    More pictures of the BBS mk2 please
  6. LUPOCHARGED
    LUPOCHARGED Paid Member Paid Member
    2 BED APARTMENT
    Something totally different to the norm:thumbup: keep up the good work watching with interest.
  7. foxyjay Forum Member
    The other Golf is my 2001 Citigolf.
    Richard Mk2 likes this.
  8. afbiker02
    Bury St. Edmunds
    I had forgotten about your citigolf, looks great. Thanks for showing and I'll look forward to the progress on your mk2 :thumbup:
    foxyjay likes this.
  9. Alfonzo bonzo Forum Member
    Good progress, my mate used a mk4 r32 pedal on his mk2 to mk5 r32 swap because he didn't want itt in the floor.
  10. The_Teller Forum Member
    Brighton
    This looks interesting.... Will you be removing the traction control?
  11. foxyjay Forum Member
    Steve- the end result will depend on how happy the transmission and engine controllers are, to be without abs.
    I will leave the abs wiring in the loom just in case. May need to find alternative abs sensors maybe mk3 will physically work....need to investigate further...
  12. mercedeslimos Forum Member
    Cork, ROI
    Looks amazing gonna be watching this one J. What's the deal with driveshafts? A guy from edition made mine for the 02M. The subframe needed modifying to clear the 108mm CVJs.
    Sam
  13. foxyjay Forum Member
    Sam, I've got the name of a good guy in Coventry who can apparently make anything ......
    I'll have to cross the subframe mods when I get to that stage.
  14. mercedeslimos Forum Member
    Cork, ROI
    Let me know if you need a hand anyway there's plenty of knowledge out there!
  15. foxyjay Forum Member
    Thank you for the kind offer - I may well be taking you up on it!
  16. foxyjay Forum Member
    Not much progress....
    Bought some mk4 golf front abs sensors to test with the octy abs pump....fingers crossed.
    Bagged a mk3 golf fuel tank.
    Bagged a stock mk2 pedal box.
    Give me something to do at the weekend!
  17. foxyjay Forum Member
    Tank and pedal box collected.....
  18. Sirguydo
    Bolton
    Congratulations that was your thousandth post lol
  19. foxyjay Forum Member
    Rear Polo hubs and stub axles with ABS sensors bagged.
    That's two benefits for the price of one! These are off Polo Mk3(?) 6N2 GTi with rear discs.
    Done a bit more trial and error with the brake pedal box and come to the conclusion that I am going to have to reuse the Mk2 brake pedal and adapt the Octavia brake servo shaft - cut off the ball and fit the end off the Mk2 servo.
    The Octavia pedal in fact is too short and the fulcrum point for the brake servo is not quite correctly located if using the Mk2 pedal box.
    On the topic of the throttle pedal - the touareg one doesn't work properly with the Octavia ECU.
    After having a good look on ELSA - it looks like there are many different variants - some petrol and different to derv ones and manual / auto also might be different.
    Going to take a bit more research yet!
  20. mercedeslimos Forum Member
    Cork, ROI
    If the octavia servo is anything like a mk4 golf one do the same as me. I chopped the ball off, threaded it with a die and used the B4/Corrado/mk2 clip fitting onto it then. Nice easy fix.
