Next question is for a high revving engine what are the best Big End Bearings. I've been looking at Calico ones but, got some info the other day for the Best ones to use. http://www.intengineering.com/4-Cylinder-VW-Calico-p7346368-1-2.html I have Original VW ones in mine , but a friend is rebuilding his engine.
I decided to raise my rev limit to 8500 max with hydraulic tappets? with the standard 86.4mm stroke crank.How about main cap's bolts? can i use the stock ones? cheers
Is that with regard to strength or wear? I am really guessing here, but. I recon. the rev. limit propably allows for long life as well as strength capability. If you look at the fact alone, that some VAG engines have cast cranks, and some forged, in what are basically the same engine, with basically the same rev. limit. Then you would expect the forged crank to accept higher revs. before failure throught strength alone. 'Blueprinting' an engine, uses standard parts and produces more power and allows higher revs.
I wasn't thinking in that much detail, more of how high you could go on a standard engine before dents start appearing in the bonnet! Would it be worthwhile putting together a list of various components' rpm/power limits? Based on people's experiences, it could be useful for folks putting engines together.. just a thought
