Engine cutting out after 2 seconds
Discussion in '8-valve' started by JayRyder, Dec 8, 2008.
  1. 8valvedub Forum Member
    good good m8 you,ll be ok even if its the immob box ,key reader coil and recode its cheap enuff but i really doubt its tht..good luck m
    black wire is an ignition live feed, dont think it would make much difference though apart from putting a small drain on the battery.
  3. lufbramatt Forum Member
    Rochester, Kent
    ah cheers for the heads up on that Jon, not had any problems yet but ill change that next time im in the fusebox, still got to investigate why my coolant light wont stop flashing!
  4. JayRyder
    JayRyder Forum Member
    Stoke-on-Trent
    Been and had a look at the car, the fuel pumps prime now when ignition on lol.
    In Vag-com the immobilliser says
    Authorised Start = 1
    ECU Answers = 1
    Key Condition OK = 1
    No. of Matched Keys = N/A
    I even tried disconnecting the ring reader to see if it was checking correctly and it came up with
    Authorised Start = 0
    ECU Answers = 1
    Key Condition OK = 0
    Plus it gave an error code about the ring reader.
    I cleared all fault code on the immo and the ecu then tried to start it. It did the 2 second thing again.
    Ran a full test on it and this is the result.
    VAG-COM Version: Release 311.2-N
    Chassis Type: 1H - VW G/J/V Mk3
    Scan: 01,02,03,08,15,25,56
    Address 01 -------------------------------------------------------
    Controller: 037 906 025 R
    Component: SIMOS 4S 2104
    Coding: 00000
    Shop #: WSC 01317
    2 Faults Found:
    17978 - Engine Start Blocked by Immobilizer
    P1570 - 35-00 - -
    P1570 - 35-00 - -
    Readiness: N/A
    Skipping Address 15-Airbags
    Address 25 -------------------------------------------------------
    Controller: 1H0 953 257 B
    Component: IMMO VWZ3Z0V4318105 V00
    Coding: 09600
    Shop #: WSC 00087
    No fault code found.
    End -------------------------------------------------------
    The immo and ecu are talking ok, im really beginning to think it is the ecu, well I just hope so.
    Ive still got that spare wire doing nothing on the immo, it grey and black and goes to TV14?!?!?!
  5. 8valvedub Forum Member
    fingers crossed for you m8 but it seems too similar to my old mk3,s fault not to be the ecu to be honest.
  6. JayRyder
    Stoke-on-Trent
    Maybe its this?? Hence Matched keys = N/A
    Clicky
    Gonna try it tommorrow!
  7. rubjonny
    what pin on the immobilisor is that spare wire?
  8. JayRyder
    Stoke-on-Trent
    now your asking! will have to go back down to the car tommorrow.
    I was thinking it may need to connect to the immobiliser on another pin to allow the start. Just guessing now and waiting on the other ecu.
  9. rubjonny
    shouldnt do the ecu and immob communicate to each other as well as the vac com port via the grey/white wire, the fact you can read from both means the wiring side is ok, but I dont recal having a grey/black wire on my mates 96 ABF immobilisor loom...
  10. JayRyder
    Stoke-on-Trent
    Its there in this diagram you sent me and goes to TV14 what ever that is?!?!?
    HERE
  11. rubjonny
    ah, my own diagram :lol:
    NOW I remember how it works, TV14 is the diagnostics junction box above the fusebox. The ECU diagnostics wire connects direct to the grey/white plug on the imobiliser unit (J...) then the grey wirefrom the imobilisor box runs to TV14. TV14 is where the OBD2 plug connects to, and all the other airbag, abs etc diagnostics wires run. If you dont have it, run it direct to the grey/white wire on the OBD2 plug.
    Basically the ECU diagnostics PASS THROUGH the immobilisor box, they dont run parrallellell.
  12. JayRyder
    Stoke-on-Trent
    You are joking! omg!
    Ive got the immo and ecu joined together via the grey/white wire and then to the k line on the vag-com port! ie in parrallelelelelelelellll
    Ive got go try this soon as!!! Makes soooooo much sense!
  13. JayRyder
    Stoke-on-Trent
    ITS ALIVE!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
    Im sooooooooooooooooooo happy!!!!!
    It was the wiring but it was like this, grey/white from ecu to immo and vag-com
    Its now, grey/white from ecu to grey/white on immo, immo black/grey to vag-com!
    Ran a bit rough, got no airbox so stuck a dust mask over it lol, cleaned all the plugs, dizzy and it runs mint now.
    Only problem i have next to no clutch! It the self adjusting cable, gonna get a new one.
    Thanks to all who helped!
    Now its time for beer
  14. 8valvedub Forum Member
    ahhhhhh well done m8 glad its sorted bit of a bummer u ordered ecu tho ,sorry m8 but it was with mine:thumbup:
  15. JayRyder
    Stoke-on-Trent
    no probs mate, ive got a spare now! lol, spares are always good.
    Just got get a manual clutch cable, sort the blowing exhaust, replug in the speedo (came out for some reason) and make the rev counter work!
    Yeah, why aint my rev counter working? have i got wire it direct or something?
    Thanks for your help though 8valvedub
    Im still very happy and have ordered a curry to go with my beer :)
  16. rubjonny
    awesome, glad ya got it going!
    ze rev counter no worky because the ECU rev counter signall from the AGG doesnt work with the MK2 clocks, you have 2 choices:
    1. Chop off the plug to the MK3 coil and convert it back to your old MK2 coil+tci setup, run a wire for the rev counter
    2. open up the MK3 coil and connect a wire to a pin inside, run a wire for the rev counter
    I prefer option 1 as the MK3 coils are shte, but its your choice :)
  17. JayRyder
    Stoke-on-Trent
    Thanks for that mate, think im going get a spare mk3 item and play with that, ive binned the mk2 one it looked well old.
    Just done the clutch cable, swapped to manual, works great.
    Need to get a mk2 airbox now, or adapter plate to fit a cone filter because the dust mask aint a good idea! :lol:
  18. rubjonny
    mk2 diesel one works, seat ibiza with an spi or diesel engine too :)
  19. JayRyder
    Stoke-on-Trent
    ive chopped the old air box up and made a very nice adapter from it lol, works great. Wacked a cone filter on it and it sounds great.
