I have the ultimate stealth. 14" steelies on me vento. Ooops, can't be "stealth" as it don't go fast.
Heres a rather poor quality picture of the centers with a VW logo on them they were on my GTD though I only got 3 as it had been in a mild OSF shunt wich knacked the wheel and so I didnt get a cap for that wheel http://hometown.aol.co.uk/SG984877/gtd+wheel.jpg anyway I'll post a new picture and part numbers tommorow they also did a cap with a small bagde towards the edge of the cap (my Jetta had a set) Edited by: A19VUU
Balls! [:^(] Got the caps today and they don't fit I use the longer wheel bolts supplied with my Ronal Turbos on all my wheels as I have spacers on the rear to clear the springs on the FK coilovers The radius of the bolt is larger than the gap in the cap
G_V_K, using whell spacers in the rear,doesn't make your car act weird!?being the back larger the the front...and another thing.did you roll the fenders!?my car,with et37 15x7 wheels with 205/50R15 rubs in the back... using your black rims to the track,and steelies on the road,is something i can't understand...i love your black rims...i have a photo at night,that is just the best a2 pic i have!!! white a2, if you don't whant your BBS rims,send them to me!!
Hidro- the black rims need repainting as the dust from the Hawk blue race pads I use has ermm, 'ruined them slightly' So they will be used on the track Only use 3mm spacers which is no different to using ET32 wheels, so no adverse effects. I use 195/50 tyres and they never rub.
i don't really get the et37 or et32 thing...can you explain it a litle!? my car will rub!?or not!?and with a spacer!?the spacer does anything for the handling!? oh,and i think your black rims,are just better then the SS or turbos you got Edited by: HidRo
ET37 wheels are further under the arch than a lower number ET , ET15 for instance REALLY sit proud of the arch
humm,then it shouldn't rub like it is,right!?even with the 205/50R15... i was thinking of getting 195/50R15 cause it rubs,and are a litle bit cheaper. about the spacers,wich is the wider i can get,to not rub!?spacers just in the back help handling!?
