Golf GTI MK2 20V UP THE REDS!
Discussion in 'Members Gallery' started by fasteddie, Feb 13, 2014.
  1. Gambit
    Gambit Paid Member Paid Member
    bout time. i expect to see more today :)
    tho i can see the amount of effort being put in - 2 cups on the grass means tell me you dont even have time to make your own tea :)
  2. fasteddie
    fasteddie Banned
    Called again today drank more of my tea and ate my buns and kept me back ....Has some cheek as I lent him a compression tester and he still hasn't used it!
    Slow G boy
  3. fasteddie
    fasteddie Banned
    Both looms now sorta sorted just to run them down legs and find a place for ecu :)
    Wee drop of wax round boots
    seen mk2's rust round these holes
    New Volkswagen servo was a must
    Old vs new
    Seat Ibiza Cupra R master cylinder fitted same as Ford focus one ;)
    My new center caps from Japan [:D]
    These wheels don't come with center caps when you buy them :(
    German Performance wheel of choice :thumbup:
    Wee links
    Click on ;)
    https://www.google.co.uk/search?q=Porsche+Volk+Te37&rlz=1C1JUFK_enGB557GB557&espv=2&source=lnms&tbm=isch&sa=X&ei=xV7uU_e4NKLT7Ab5_4DQAw&ved=0CAYQ_AUoAQ&biw=1440&bih=775
    https://www.google.co.uk/search?q=Porsche+Volk+Te37&rlz=1C1JUFK_enGB557GB557&espv=2&source=lnms&tbm=isch&sa=X&ei=xV7uU_e4NKLT7Ab5_4DQAw&ved=0CAYQ_AUoAQ&biw=1440&bih=775#q=BMW+Volk+Te37&tbm=isch
    The power cable to hide battery in the car
  4. Gambit
    have used it :p
    I actually meant to take a sneaky pic of your bike in the garage stuffed in the corner where it belongs lol
  5. fasteddie
    fasteddie Banned
    Dash in to see what room I have under it for ECU tis looking good :)
  6. fasteddie
    fasteddie Banned
    It's a grim day so it's into the shed again ...must be more to life [:s]
  7. LUPOCHARGED
    LUPOCHARGED Paid Member Paid Member
    2 BED APARTMENT
    Good to see progress :thumbup:
  8. fasteddie
    fasteddie Banned
    Wiring and more wiring [:s]
    Working through wiring today, wanted to utilize the holes in the shell
    Nice wee blanks in the chassis, removed these and found me some Vag Grommets to fit in nice
    Front wiring and plugs
    Ran the rest of the wiring through scuttle to hide it and take part of it to the ecu in to car via the heated washers wiring grommet
    Wiring ran down both legs and brought up through leg to the washer motor and a loop earth I added
    beetie and vr6smith like this.
  9. odub Forum Member
    Colchester, Essex
    This build is epic. Your attention to detail is spot on chap
  10. Gambit
    4 days in a row!!! I was gonna slabber this morning but thought id sit back and wait :) just shows ya doesnt it when you decide to engage yer brain what can happen :) Sept will be 2.5yrs ;) target time!
  11. fasteddie
    fasteddie Banned
    See when you taking your car to Stealth to get the fueling set up ........ha ha your not ...your in belfast and its only me can do it ....you need to start bringing M&S Buns with you ;)
  12. Sirguydo
    Bolton
    Nice work Eddie :thumbup:
    All it took was a bit of bullying of the forum to re motivate you you slacker lol;)
    Keep up the good work you'll have it all ready to cover up till spring as summer seems to be disappearing [8(]
  13. Carbs4ever Forum Member
    Portadown
    Tornado red or "light breeze" pink? Yeeee hoooo!!!! Looking well young scissor hands... Get it down my way some evening...
  14. fasteddie
    fasteddie Banned
    Sorting battery cable and finishing wiring earths etc
    To wiper motor and the other to Emerald inside car
    Battery cable Grommet in leg and lighting wiring run
    Center tail is for sensors and starter etc ..right hand tail is for level sensor in coolant bottle
    loop earth
    Sirguydo likes this.
  15. fasteddie
    fasteddie Banned
    Finding bits I've put away is melting me [8-}] real bad [:x] not good ....:(
    want this finished so I can put it behind me with a cover over it.....its gonna happen [:[]
  16. Sirguydo
    Bolton
    It's called getting older and being busy [:s]
  17. fasteddie
    fasteddie Banned
    Battery cable sorted ..bit of G sheet cut to fit the inset and keep feed cable safe and reseal floor :)
    Bit of hard wax sealer
    Where it comes out :)
    sorted
    Next up was sort out the wiring on rear of Dash
    New feed added etc
    Dash fitted
    My Wideband and anything else you want, it does it all :thumbup:
    Cover time [:D]
  18. Lewvw New Member
    Gloucester
    This is coming along nicely :)
  19. jonnycab New Member
    perfect job on the battery cable! i like!! :thumbup:
  20. fasteddie
    fasteddie Banned
    Thanks
    Just a bit to finish wiring then black brake pipes all round ;)
