Who has this kind of set up? I just wired up mine and I quite like it because I don't like the radio. Basically what I have wired is iPod through an RCA into a 4 channel amp which I have my speakers wired up to. The amp is nicely concealed under my passenger seat and the wires under the carpet, it also confuses car thieves who won't see a radio to steal. Pics coming soon.
Never really thought about it tbh - can only see it being much use with an Ipod and the safety side of it you stated. I like my 5-live on the way home tho...
Well you can fit an FM transmitter in somewhere which I'll probably do somewhere down the line, I got sick of the radio a while back though so I'm pretty happy with my system. I just need something to cover the damn hole in my dash. Might stick an old tape deck in and leave it unplugged or something.
Or I could just yank one out from the scrappy for a quid, whichever I can be bothered to first. Thing is, I'd rather have a cubby hole.
I've had this for a while now, little amp in the glovebox running 2 mids, 2 6x9's and my sub. Fitted it after scumbags stole my TV, DVD, headunit, amp, sub (which they left down the street for me bless 'em), iPod, every CD I ever owned [:^(]... Amongst other things... There's an extra foglight switch on the dash to switch it on and everything, stealth
Nice with the fog switch, mine's running so it's turned on when I turn the key. How's the wiring done on your switch? I'm quite curious about running a switch aswell.
Remote to live with a foglight switch in it, easy. Just a pain in the **** when I forget to switch it off overnight...
There is that. I'd like to have it on a switch but it still get killed off with the ignition, can't think how, would have to split the wire surely?
could you just run a buzzer like the guide on how to run a buzzer to go off if you leave the headlights/sidelights on a mk2 on. wired from the interior light-coming off the fag lighter and the headlight loom.
i had this set up in my camper wagon only downside i found was limited adjustability, why not trtack down an original radio to fill the gap? it dont have to work
Same as this 99p on e-bay one? And could I just use one of these tiny amps to power 2 x 13cm speakers?
you all so get one's with female end's that will plug in a rca lead wich is a bit better if the amp is in the boot you can get them in a hifi shop
1990, that set up will work yes. I think I'm going to relocate my amp to somewhere that it won't be affected by things in the car like passengers. I need to build something that protects it.
