Help! Abf fueling issues?
Discussion in '16-valve' started by matchowmk1, Jul 30, 2022.
  1. matchowmk1
    matchowmk1 Paid Member Paid Member
    Portsmouth uk
    I had a free hour today to get back to stripping my loom down and removing the burnt out mfa wire and I got about half way to the bulkhead and found that the mfa earth joins onto a brown with red wire? Do I need to remove that as well or is it important?
    heyup that brown/red used to go to the coolant level warning sensor, it can be stripped out.
    with the mfa issue see if you can find a male spade near the fusebox on the dash wiring with a brown and brown/white, you need to earth this
