right - i have no idea how long a key number is, but the 1116 would seem promising....now where'd you park your car yazz?
Thanks Yazz - just phoned the locksmith back, he said thats defo a key number, so should have one stamped on mine also - incidently, he says they are normally only found on the passneger side! good news, as from the number I can get a accurate key cut! Great!
I'm guessing thats at me, as madmonkey was saying to check them all along - legend! But i was getting conflicting advice tbh, but now it's confirmed. Thanks all.
Hope you get it sorted, i've found my passenger handle and there's no number on the lock barrel!! But i do remember the car had a bit of damage under the passenger handle so it might have been a replacement lock.
It's just I went through a phase of buying a brand new key from VAG for every car I bought. Found the best way was to remove the drivers lock barrel (if they were all the same) Just made putting the key in the door and ignition that much sweeter.
Got my key number guys - it was stamped on the passneger door barrel as promised! Now fingers crossed for tomorrow when i get the key cut....sod's law says it won't turn the ignition For reference - the key code is located here, and i checked the driver's barrel and there was nothing stamped but i'm guessing it could easily be on that side too:
