Hi I wonder if there is other link with the guide for the 2.0 9a engines for corrado of how to tune it this one is not worrking
I have both these problems; odd occasional random miss/hold-back and my tacho drops straight past 2/3k down to ~1000 (occasionally dies) with a fast fall. No leaks on the the over-run valve piping that I can see. I've electrically charged it and it audibly clicks. I have good ign live on the yellow/black wire. As far as I can tell; no switched earth on the brown/black (BUT i'm not sure in what situation it should have a signal?? at idle from cold start?) Is it likely my ISV control unit is dead? Presumably that would be the likely culprit for the hunting and rich idle I have too?
the brown.black is triggered when you lift off from high rpm by the isv controller, have a look at the red/black wire from the controller to the spade connector near the coil and check the brown/white wires to the head as one of them is for the isv module
So If I rev it up to 5000 and let off the throttle I should see continuity with body earth on the black brown? could you advise what/how should I check the other two?
yep. easy to check the brown/white is good just check for ignition voltaghe between the black wire and the brown/white on the isv controller plug, for the red/black check for continuity between the isv pin and the coil negative
