HOW TO: Check, repair and tune your MK2/Corrado 1.8 16v
Discussion in '16-valve' started by rubjonny, Jul 16, 2009.
  1. rubjonny
    updated with fuel injector test info :)
  2. stereoflaver New Member
  3. karmannski New Member
    Hi I wonder if there is other link with the guide for the 2.0 9a engines for corrado of how to tune it
    this one is not worrking
  5. pingman New Member
    I have both these problems; odd occasional random miss/hold-back and my tacho drops straight past 2/3k down to ~1000 (occasionally dies) with a fast fall.
    No leaks on the the over-run valve piping that I can see.
    I've electrically charged it and it audibly clicks.
    I have good ign live on the yellow/black wire.
    As far as I can tell; no switched earth on the brown/black (BUT i'm not sure in what situation it should have a signal?? at idle from cold start?)
    Is it likely my ISV control unit is dead?
    Presumably that would be the likely culprit for the hunting and rich idle I have too?
    the brown.black is triggered when you lift off from high rpm by the isv controller, have a look at the red/black wire from the controller to the spade connector near the coil and check the brown/white wires to the head as one of them is for the isv module
  7. pingman New Member
    So If I rev it up to 5000 and let off the throttle I should see continuity with body earth on the black brown?
    could you advise what/how should I check the other two?
  8. rubjonny
    yep. easy to check the brown/white is good just check for ignition voltaghe between the black wire and the brown/white on the isv controller plug, for the red/black check for continuity between the isv pin and the coil negative :)
  9. wone New Member
    thank you
  10. GVK
    Rubber Jonny is mentioned here :p
    rubjonny likes this.
  11. rubjonny
    Finally! My big break, I have arrived :lol:
    costel1969, GVK and AKAeddypeck like this.
  12. GVK
    Check the comments, in a moment of confusion he thought that I was Rubjonny lol
  13. Zacmk2 New Member
    hey guys hope everyone is well.
    Read this thread thoroughly an is very helpful.
    when i disconnect the black and red to the isv. my kr wont start one bit. any ideas. only just bought the old girl the other day and she is low on power and idling poorly.
  14. rubjonny
    wind out the idle screw a bit that should hopefully get it going
