I believe you can use modded Nissan Primera injectors and I'm sure someone will be along shortly to confirm
Nissan JECS SR20DE and DET side feed ones do work but you have to fabricate a top cover for the plastic fuel rail housing. Does not look pretty, but does work.
Was thinking about a 1.8T rail and inserts for the manifold .. Seen it done in the USA .. Anyone here done that ?
apparently if you split the ABF fuel rail and leave the bottom half attached to the inlet bog std bosch type injectors will then fit into it, this came from a mate of mine who was playing with cossie management, lancia dizzy and pug iirc throttle body on his turbo RE2000 16v a while ago would need to make a bracket to hold the injectors in, plus not sure if the oem rail would reach to the injectors. he had chopped his and welded on a 1.8t inlet see
Do you have pictures of it. Would have thought the space under the curve makes using EV series injectors and a 1.8T fuel rail difficult.
heres another solution, bit more elegant: http://www.clubgti.co.uk/forum/showthread.php?t=123109&page=2 either of the above could work on abf manifold with the lower half of injector rail trick? weith some carefull trimming it could be made to look neat enough i expect
i bought one from E-Bay in the states half the price of the Eurospeed one 65 sold it to a fellow club member for a KR Turbo project. its the one in the picture with the injectors fitted.
But what about larger injectors or solutions to the ABF/ADL inlet manifold? KR/PL/9A engines are already catered for? A link here starts to describe what is involved to covert to EV style injectors ( more options with this injector) and a 1.8T or BBM fuel rail. Seem to invovle some sort of insert to fit the injectors deep into the injector hole for seal and to increase clearance for the rail. The 1.8T rail was not shown fitted or working in the first pictures. Just inferred that it will fit with the EV1 injectors. EV1 injectors with some sort of insert from the link. Another picture with the 1.8T rail with AFPR and EV series injectors from the same manifold.
toyo as i said earlier, a mate got this to work by splitting the abf injector rail in half, then apparently bog std Bosch injectors fitted straight into the lower half of the abf fuel rail he said then the issue was just to make up a bracket to hold the injectors and rail firmly to the inlet, iirc he used a 1.8t fuel rail with that combo? i could ask him if you're interested. he wanted me to talk to you about getting his car tuned up with megasquirt anyway
i think hes binned it all off now and done it the normal way, 1.8t manifold welded to 16v bottom bit, but will ask him again about the abf rail thingy
Thanx Chaps.. I wonder if the ADY inserts will fit snug into the ABF lower mani , in any case - inserts wont be an issue to make up ..
yeah he confirmed at one time was using lower half of abf rail to fit strd bosch injectors, but its all been swapped with other gear now. he is actually on omex injection if you know much about that?
