K-jet breaking the double ton barrier has been reached and broken!! Speedo went to Stealths this morning and has managed a 202.5 run ! No idea on the torque figure - have pm prof to sort a power flow torque graph thingy !! Gonna be fun at mallory !
Theres no TB's on it Jimmy Straight 276 Shricks and a flowed head. Runs a standard ABF bottom end and K-Jet Well done to Paul is all I can say!
It`s just a RE2000, 276`s and nearly 9 years of track day abuse!! I took the head of a couple of weeks ago to replace the valve stem oil seal`s, (first time in all these years), and she was as clean as the day she was born . Just show`s a good spanking does the trick...
Vince is sending the file over asap so will mail to GVK for posting. I'll plot Barney and MattD against it
right it's found me D drive now so I have plotted them, looks like a very good setup indeed, Paul is yours on a 42mm manifold still, it gives a very different power curve to barnys
Velly did you run at stealth? what's your reg number mate, I'll see if i have the file also whats Matt Ds reg I can't remember
