Koni Adj Dampers
Discussion in 'Chassis' started by mark_vr6, Nov 12, 2003.
  1. mark_vr6 Forum Member
    Hi All. Getting these fitted shortly (with powerflex rear wishbone bushes) to compliment the Eibach ARB's and springs and I was wondering...........
    I expect the garage will set them at the least firm setting but does anyone have any preference as to setting the front vs the rear for handling bias on the road. I know you will just tell me to go and mess about with them but I am just interested! :)
    Mk 3 by the way :o
  2. GTi69 Forum Member
    Hucknall, Nottingham
    I would be interested in this also, i have the t/a konis with eibach springs. I have just left the fronts on soft and the rears a little bit harder. It still handles really well and i get some comfort too!
  3. jamesd Forum Member
    Ireland
    I have been told by a VW tuner here that thats the best way to set them as well and he said in a year or so to go a little harder on the front and then some more on the rear.
  4. jc.. Forum Member
    Virgin Islands
    Do your rear koni's have top adjustable units that are the same as the front ones?
    Haven't fitted them yet.
    Mine have an allen fitting but I can't see that turning once in situ with spring pressure and nuts holding it in place.
    The front ones have a inner fitting on the damper piston at the top so the inner bit turns when you put the little white knob on it.
    Anyone got these fitted already?
  5. mark_vr6 Forum Member
    Mine are (will be) adjustable with the white knob front and back.
    Im guessing that for raod use you will not stray far from the low firmness as per Gti69 and increase them for the track?
    Looking forward to it [:^:]
  6. GTi69 Forum Member
  7. jake Forum Member
    Saint Kitts
    I run my mk2 with about a 3rd from softest at the back (I have to remove those fatherless childs to change the setting) and I tweak the fronts depending on mood but mostly run them about a 1/4 turn from softest.
    (H&R springs and stock arbs BTW)
  8. KeithMac Forum Junkie
    Kazakhstan
    JC, it sounds like you haven`t got the t/a`s for the back, you have to specify this when you order them as they come off corrado`s.
    The other rears (for the golf) have to be taken off to adjust the damper setting which is a right t**t!
  9. jc.. Forum Member
    Virgin Islands
    "My rear ones are adjustable the same way as the front ones, they are a bit fiddley but i can live with that. I think the rear Koni's were for a Corrado but they still fit a golf, i may be wrong though. "
    I am told by Venom that all rear Koni's for VW's are non t/a. Is this b*****ks?
    What did you buy, where from and how much?
    I feel like I have been fecked over here!!
  10. mark_vr6 Forum Member
    They are top adjustable at the rear as well. Talk to awesome. ;)
  11. Pike Forum Member
    Does anyone know what sort of life-span the koni's are supposed to have?
  12. GTi69 Forum Member
    I ordered mine from Vince at Stealth, i thought it was only the fronts that were adjustable so i was very very suprised and pleased when i opened them and the rears were adjustable too. I was very lucky i suppose, i think if i had ordered them from anywhere else i probably wouldn't have got rear adjustables!
    I can't remember what i paid for them now, but i think it was somewhere around 350.
  13. jc.. Forum Member
    Virgin Islands
    Been shafted here, about to tear someone a new asshole!!!
    For those ordering:
    True top adjustable (on car)Part no. 8041-1108 sport
    Off car Adjustable Part no. 8040-1043 sport
    10 difference in it
  14. KeithMac Forum Junkie
    Kazakhstan
    Venom are indeed talking bollox!
  15. KeithMac Forum Junkie
    Kazakhstan
    I got mine from C+R, told them I wanted t/a rears and they came right first time..
  16. fthaimike Forum Addict
    Iv'e got This koni kit fitted to mine with eibach ARB and struts all round and both front & back are adjustable, you can even buy height adjustable too (not sure if koni).
    But while i was doing my stuff with the Golf Mag on monday i had the front & back set to full stiffness & had trouble cornering V fast without loosing the back end so i think i'll try softening them up a little.
    (i was doing 125 & dropped down to 70 to turn but spun 180', how weird;)).
    I heard the best setup is koni dampners & eibach springs?
  17. fionn Forum Member
    Ireland
    I got new koni's from Venom yesterday, both front & rears are TA.
  18. GTi69 Forum Member
    My rear Koni's are height adjustable.
  19. Greenmk1 Forum Member
    Yeah, so are mine [:D]
  20. fthaimike Forum Addict
    mine aren'theight adjustable [:^(]but i dont have a problem with the rear, it's the front that seems to be high on the standard kit?
    when i was putting it together i remember something about some grooves having something to do with height in the instructions?
