mk1 caddy 24v turbo 4wd project ,stress...56k warning
Discussion in 'Members Gallery' started by powernut, Oct 4, 2008.
  1. powernut Forum Member
    new stan alone is here, this is the megasquirt ms3 ecu ill be some how useing 6x ls2 coils
    hopeing to get complete vag vr6 loom out an fully instail this
  2. powernut Forum Member
    well ive no need to change the engine but im going to see how a mk5 r32 turbo holds ,
    so far stripped the lump , added a mk4 r32 forged crank to safe
    headspacer,
    modifyed some 530cc injectors,
    made a alloy welded manifold
    modifyed a mk5 fuel into a mk4 style
    rewired the engine for ms3x and vvt wired up
    added ls2 coils
    trail started on the floor
    ive got the gearbox in bits changeing ratios at mo,
    then need to make a exhuast turbo manifold
    then add hx40 turbo
    quick pic
  3. benny Forum Member
    Mate, that's a lot of inlet manifolds! Blimey!
  4. aidanb22 Forum Member
    Redditch, Worcs nr Birmingham
    Theres a fast and the furious joke in there somewhere!
    Good to see some more updates
  5. bantan45 Forum Member
    Wat is it something like, your running that much nos your going to blow the welds on the intake,lol
    but no nos just pure psi,
    go on powernut crack on lad good work
    p,s i need your help ive got a alloy that has made love with a kerb and is in need of urgent attention
    take a look and see if you can offer any help
  6. powernut Forum Member
    thing is u dont realise how mutch air air is compressed in a box area, hernce when it ballons up and you hear a nice ,,pop ,,, u know more modifying is needed , so 8mm alloy dosent pop just pulls :) ive got 6 gearboxs in bits here ,looks like a cog shop :lol:
    regards wheel pal , as its bent , they usely break when trying to bend them , back , as id basicly , break the lump out and re weld it straight then regrind the back , ud , need to spray the wheel throw ,:thumbup: yes can be sorted ,maybe cheeper finding another wheel
  7. powernut Forum Member
    added a little leaf blower
  8. powernut Forum Member
    new manifold arrived arrived and thought id do a trail fit ,all seems good,,,..but hit a issiuse
    didnt realise these manifolds are for t25 turbos , and mines a t3 ,, sdue to were external wastgate is shown, its in the wrong place , so that turbo intake is wrong way as well ..
    so bit of adapting is needed first manifold
    then chopped t25 flange off and welded a cast t3 flange on along with ,moving external wastegate too
    notice now the intakes on the left and not on right ,
    notice were old wastegate is now , ill just make a blanking plate , so then manifold can be used both ways
    trail fit time
    fits good , also i can now not only fit a turbo either way , but also spin the intake snail 360deg for any pipe angle ,,
  9. powernut Forum Member
  10. AjVR Forum Member
    You are literally mental , haha I hope to see this on the road one day. What boost level you going to , are you running a spacer plate in this motor?
  11. powernut Forum Member
    mental lol me , just open minded ...........the 12vr6 is boostinf 25/30psi the r32 carnt boost this mutch due to none forged internals , 15/18psi max, unsure what you mean by spacer plate?
  12. wadders
    wadders Forum Member
    Brighouse, West Yorkshire
    Looking good! You'll be going deaf listening to that thing rumbling...
  13. seanr68 Forum Member
    Dewsbury
    I think i just did a "sex wee"!!
  14. powernut Forum Member
    well thought id try a mk5 r32 and adapt it in my caddy and add a blower , only low boost im affraid ,:thumbd: but made a start made a new alloy poloybush mount, new paddle clutch tdi 4wd gearbox,6speed
    made a new stainless exhuast, custom intercooler pipe work, and plenty of wireing to plum up lol , few pics here
    grrr didnt relise mk5 r32 clutch carnt be used on a 2.8 4motion solid flywheel , (differncernt depths)
    trail fitted
    few sensors added , my save a few lights flashing on the dash
    made as mutch free..ish room i could in the space i have left
    then hit a issiuse exhust carnt go under car, and trying to fit a large hx40 turbo on this manifold was a tw..t , but bit of modifying turbos fitted and made a new exhuast pipe
  15. powernut Forum Member
    finshed exhuast , just need wrapping
    tig welding coming on i reckon...
    fits good
    next made some custom alloy tubing and buzzed them up
    up to date , intercooler to finish off then start on the wireing to get the buggar runing
    .ps bit of advise how mutch boost will a 38mm hold on a r32 before boost creep?
    andany one have a ekta water piping daigram ,plus a 96 mk3 vr6 obd2 8pin wireing , as my other laptps gone down
  16. Tristan
    top work on the piping there fella.
  17. powernut Forum Member
    thanks pal, well its done in modifyed and running lol
    quick runing video:)
    View My Video
  18. sum1
    sum1 Forum Member
    Somerset
    Wow! How many hours are in your days?!? You seem to achieve more things in a day than i can get done in a year.
  19. nhoj62
    nhoj62 Forum Member
    nailsea
    awesome work powernut!
    you seem to get so much done in such a short time, it is amazing!
  20. powernut Forum Member
    i dont like to hang around drinking tea , as i get idea after and get a little carried away tbh lol , then i think whats next ,errrrm couldnt find anything/engine modifyed , been for a cruise tonight and its totaly differnert to drive and dose feel nice evern with the 6tdi gears,
