Thanks sam do you think it has genuine parts as the car was an ex-demo vw dealers had it for 3 years. To me it has genuine vw parts to it as all wheels have speed sensors made by vag germany also the ecu has been programmed to be able to use cruise control. Thanks
It's a dealer fit, my point still stands, it's not factory fit. I know exactly where I'm coming from.
Yep - definitely factory fitted. It's quite common for VW to occasionally send employees down to Conrad (the German equivalent of Maplin) to buy weird switches and things, fit them into a square-ish hole made by wobbling the drill bit around, and then use Dymo tape to label them. :/
I have exactly that same momentary switch from Maplin/Tandy/Radio Shack (delete as appropriate back to the '90s) to operate my solenoid boot release. I put it underneath the dash by the fusebox out of sight. I still made sure it was straight. On topic - after having cruise control for the last 5 years I would never buy a car without it. If a how-to for the MK2 is available that would be awesome! And if the parts are relatively easy to find....
It might be easier to find Passat parts and adapt them but even then it's a pig of a job because you need to find a Passat in the scrappers then you have to find one with cruise. Sod that.
Diagram as promised. It's a quick ms paint skills mock up Check out RJ's fuse box faq for the pins http://www.clubgti.com/showthread.php?219775-Fusebox-FAQ
I like the idea of this, but I'd be a bit apprehensive about the the twin throttle cable mechanism. I've just noticed the duplicate picture of the on the previous page was supposed to be linked to (delves into photobucket library) this picture of the actuator
Hi all the throttle cables are factory as it was a vw dealer fit. when you accelerate the throttle is hard and soft as usual as it has twin throttle so when you activate the cruise control it bites on the 2nd throttle cable and maintains the speed. if you need any detailed pics please let me know thanks 16oak
As referred to earlier, on my 20vt dbw mk2 ive heard rumours easy to fit cruise can anyone elaborate I know u need stalk but any definitive list
dsj20v...if you are using the o.e. ecu along with clutch pedal and brake pedal switches, vehicle speed sensor etc then you could find th E info required based on the car the electrics came from
