Mk2 GTi Syncro Build - Operation MOT
Discussion in 'Members Gallery' started by Savagesam, Jan 12, 2020.
  1. Savagesam
    Hey, can’t say no to car parts! [:D]
  2. Savagesam
    Oh no :(
    look at me goooooo
    TonyB, erreesse, dodgy and 2 others like this.
  3. Tristan
    We're tarts for shiny stuff, aren't we?
    cupracraig and dodgy like this.
  4. Savagesam
  5. Savagesam
    Well doesn’t look like much today but feels like a massive step in the right direction.
    started putting my pretty brakes on, sadly I forgot about my front discs and they were a bit surface rusty so I cleaned them up. I my 256 pads didn’t fit? I thought they did?
    God these wheels are awful.
    Then onto the back, thanks Mr Newman for the discs but didn’t have a rewind tool so I couldn’t fit the rear pads either :(
    and then got my NSR shaft in as I couldn’t get the inner CV in the moving position.
    got my haldex thingy off for modification and my hand brake tubes for clean up.
    let’s hope one of these fit..
    erreesse, dodgy, Mk2daz and 1 other person like this.
  6. Savagesam
    Now to make heads or tails of this thing
  7. daNpy Forum Member
    NL
    I made my own from a 40 mm tube ;)
  8. Savagesam
    I have no 40mm tube and the tool was at my dads work. So I’ve bought another tool, £16
  9. daNpy Forum Member
    NL
    Not too expensive, and probably a bit better than a home made :thumbup:
  10. Savagesam
    After many hours…
    I celebrated with:
    then I tried it…
    I’m now sure the reason my keypad screen doesn’t work is because it isn’t I2C so everything in the code is expecting I2C but it can’t find it. As that screen above is as you can see, on I2C
    KeithMac likes this.
  11. Tristan
    I have no idea what 12C is, but yeah, I thought as much myself.
    :lol:
    Savagesam likes this.
  12. Savagesam
    It’s Magic
    daNpy likes this.
  13. Savagesam
  14. dodgy
    Sounds like it's playing the bagpipes!
  15. Savagesam
    Well not a huge amount done today. Got the pedal box, servo and column in.
    This is the second plug plugged in, the first was the pedal :lol:
    Holy moly..
    Even put the wheel on, indicators and plastics in then started on the fuse box wiring. This is the first time in my ownership the wheels have been attached to the steering wheel. Feels like a big achievement.
    Once they were in, plan was to get the brakes plumbed up but my rear caliper had other ideas and so did my hand brake cables.
    the cables we thought were too long but these are the “longer” cables so we found a mk2 golf tube and chopped it down to the length i needed and just put it in line to see if it would help, it did. So I’ll weld them in and we have a working hand brake!!
  16. rubjonny
    yeah you need the shorter cables, post 88 1600mm. or maybe syncro ones which are the same as mk3 golf at 1613, but then you dont have a syncro tunnel so...
  17. Savagesam
    So… we make stuff!
    It’s super thin so wasn’t fun but we got there…
    That kink looks so much worse on the picture. It’s barely noticeable in person
    these are the shorter cables as dad bought them for his but he needed the longer ones. The longer one are waaaay to long.
  18. Tristan
    Adapt
    Improvise
    Overcome.
    Look, Sam is becoming a US Marine! :p
    afbiker02 likes this.
  19. Savagesam
    There is no end to my talents!! :lol:
    afbiker02 and Tristan like this.
  20. Savagesam
    Well.. dads Mk2 sold so I’ve claimed the garage for the winter to get it running.
    The spot it sat in for 2 years.
