Odd Camshaft Markings - 8v Hydraulic Cam
Discussion in '8-valve' started by Mike_H, Sep 28, 2009.
  1. Mike_H Forum Addict
    Anyone seen these on the end of a Hydraulic Tappet Cam? A mate's just pulled the rocker cover off a car he's bought (2.0 8v Mk1, with a hydraulic head).
    On the gearbox end face of the cam is stamped GK in an oval (about 5mm High) and H1. It's got 11.3mm of lift.
    We think it's probably a regrind - anyone got more info?
  2. drunkenalan Paid Member Paid Member
    Leicester
    are you sure its a K kent stamp there cams at that end, I have a had A GS2H however i dont think the GS1 has quite such a lift..
  3. Mike_H Forum Addict
    Yup... Every aftermarket cam I've had in my hands has been stamped on that end. I'm wondering if it's a custom job they did for someone (most of the manufacturers will do that if you ask).
    All the Kent cams I've seen have had "KC GS2H" or something similar stamped on them. Pipers all seem to be BP and the duration number, Newmans have a different nomenclature including the duration, and Schricks have their part number, in a display of ruthless germanic efficiency ;)
  4. drunkenalan Paid Member Paid Member
    Leicester
    the only thing i can find with GK cams are typically V8 engines from the states
  5. drunkenalan Paid Member Paid Member
    Leicester
    Ill have a look at the cam i have from autosprint, to see if that is marked
  6. Mike_H Forum Addict
    Any news on this, Al?
  7. POL
    pol Forum Member
    Scotland
    had a bit of a hunt as well mike but couldn't find anything.
    could be a little known european mob...
  8. Mike_H Forum Addict
    Al tells me there's nothing stamped on his Autosprint cam...
  9. drunkenalan Paid Member Paid Member
    Leicester
    does mr shed have any ideas?
  10. drunkenalan Paid Member Paid Member
    Leicester
    could it be a gti engineering cam or did they use a specific brand?
  11. Mike_H Forum Addict
    GTI Eng used schrick cams on 8v's, but ground the numbers off (you can still see them faintly, normally).
    Most of the 16v's used KR cams, with Schricks available as an option.
  12. drunkenalan Paid Member Paid Member
    Leicester
    MR shed??
  13. Mike_H Forum Addict
    That's not the source of that info, if that's what you mean.
  14. drunkenalan Paid Member Paid Member
    Leicester
    no i mean is he familiar with the markings??
  15. Mike_H Forum Addict
    No I don't think so... he doesn't really have much to do with cams, just heads, heads and more heads.
  16. drunkenalan Paid Member Paid Member
    Leicester
    i wondered he had setup any solid lifter cams for people in the past.
  17. Hotgolf
    Smelly Cornelly
    GK was found on a GTI engineering cam I had years ago, and also on a modfied 16v Schrick that was in the classifieds a while back. I think Paul H. might even have the cam now.
    Check the lobe sizes to see if it's a regrind.
  18. Mike_H Forum Addict
    Interesting. Cheers, Mart. It came with a ported head which looks like work from the shed, so could be GTI Engineering in origin.
  19. Mike_H Forum Addict
    He can set up solid lifters, but doesn't do conversions from hydraulic.
  20. drunkenalan Paid Member Paid Member
    Leicester
    hmm thats interesting, i was going to pop in and see him to discuss some possible head work, i guess i may need to use the old audi head instead, the problem is its a carb'd head so smaller inlets
