Odd Camshaft Markings - 8v Hydraulic Cam
Discussion in '8-valve' started by Mike_H, Sep 28, 2009.
  1. Mike_H Forum Addict
    I don't follow you - why does that mean you need to use the Audi head? Didn't you already get a pack D done a couple of years ago?
  2. drunkenalan Paid Member Paid Member
    Leicester
    yes i have the head from a couple of years ago, but the F3 ITB's clash with the injector holes, so i could do with using a carb'd head really, only problem is they come with 38mm inlets, so ill have to change inlets and outlets increasing the cost.
    ill have a chat with him
  3. Mike_H Forum Addict
    I'm trying to picture that... is it really the holes or just the inserts they foul on? Any pics of the problem?
  4. drunkenalan Paid Member Paid Member
    Leicester
  5. drunkenalan Paid Member Paid Member
    Leicester
  6. Mike_H Forum Addict
    I can't see those vortex pics, the other ones don't show the fouling of the throttle bodies. Why not have the extra bit removed and welded up. It would be cheaper than having another head done... or could the throttle bodies be modified? Spacer plate made from an old PB manifold flange?
    Hijacks and diversions are fine if it's an interesting topic ;)
  7. drunkenalan Paid Member Paid Member
    Leicester
    i have a flange that i had cut when i was going to use ITB's, could be a spacer, the problem may then come that im pushing the TB's against the firewall.
    Ill take a few pictures tonight.
  8. drunkenalan Paid Member Paid Member
    Leicester
    break this into another thread if you want mike
  9. Mike_H Forum Addict
    Surely to do this properly, and get the benefit from your fancy kit, you should put a mini-on-webers-type airbox in the firewall anyway? Assume the scuttle is chopped already?
  10. drunkenalan Paid Member Paid Member
    Leicester
    carb head noticed top of inlets ports
    See GTI Head
    the flange i had cut needs porting and cutting to clear exhaust ports
    Note throttle mech is over the mating face
  11. drunkenalan Paid Member Paid Member
    Leicester
    i have done some measuring and they should fit in the engine bay without major surgery, altho im going to check before it try fitting them, in the GTI engine bay
  12. drunkenalan Paid Member Paid Member
    Leicester
    fitted to the carb head
    a similar angle from the driver engine bay
    if they really wont fit ill remove the back fibre glass section and get a plate made to bolt some trumpets too
  13. Hotgolf
    Smelly Cornelly
    X flow head?
  14. drunkenalan Paid Member Paid Member
    Leicester
    no mart the carb head is a DT from and 83 audi 80,
    or do you mean they will fit a x flow head?
  15. Hotgolf
    Smelly Cornelly
    lol. yeah, fit a cross flow, I ain't that dull...............well, not yet ;)
  16. drunkenalan Paid Member Paid Member
    Leicester
    the ITB's wont fit a x flow head, well none that I know of. I dont mind a challenge, im sure I can get them to work with good results
