Rear Brake Conversion - apologies in advance
Discussion in 'Mk2' started by PhilRyder, Dec 14, 2021.
  1. PhilRyder
    That's what I queried and got the answer as above.
  2. Zender Z20
    Needed the plastic roller (5) as it'd split, but was able to salvage the inner metal sleeve (4), listed as separate parts, both still available -
    https://www.deutsche-parts.co.uk/321612367-new-genuine-part.html (plastic bit only)
    https://www.golf1onderdelen.com/product/3630/ (both bits)
    Whole lot sits behind that hex bolt / washer.
    If your getting a new regulator, check it comes with the triangular plastic clip that fits to the other end of the spring (it's not shown on the schematic)
    The tension spring might be these, though the part numbers differ (191 612 339 against 171 612 339)... Werk34 state it'll fit the MK1 and MK2, the other site just states MK1... will need double checking.
    From what I can tell the MK2 springs ends both bend in the same direction, the MK1's in opposite directions if that makes sense,
    but may work the same if Werk34 are listing it for both?
    https://www.golf1onderdelen.com/product/veer-remdrukbegrenzer/
    https://www.werk34.de/en/tension-spring-for-brake-pressure-regulator-612.171.339.html
    Werk34 also do a repro. bracket.
    https://www.werk34.de/en/brake-pres...-fits-for-golf-mk2-corrado-612-191-407-b.html
    PhilRyder likes this.
  3. PhilRyder
    That's all really helpful, thank you.
  4. Tristan
    Good to know.
  5. dodgy
    That's why mine had it then being an auto, thought it was because it was late car, run out model and all that. Cheers
  6. PhilRyder
    Axle has arrived. Not in bad shape and everything seems to be there.
    It will be interesting to see if this is salvageable……..thoughts?
  7. Tristan
    Honestly... I'd replace it, because, well, brakes.
    But knowing there's new one's available, no harm in opening that one.
  8. PhilRyder
    Agree, investigate and perhaps replace.
  9. PhilRyder
    Tristan, you mention opening this up. It seems to be in fairly good nick on the inside of the bores so is it a case of undoing this nut and cleaning what falls out? Is it worth putting the parts in an ultrasonic cleaner?
  10. Tristan
    Years since I opened one, iirc yes?
    I might have a duff one here, I'll root around and report back in the afternoon.
    Though I have a sneaky suspicion it got binned
  11. PhilRyder
    Thank you
  12. Tristan
    Sorry Phil, I've spent ages looking but I can't find it.
  13. PhilRyder
    Thanks for trying, I appreciate it :thumbup:
  14. PhilRyder
    My next question is, is how much is the lever supposed to move?
  15. rubjonny
    that nut will allow the lever to come off, under that is a rubber boot which covers the return spring and operating plunger. from there you can then start to strip the valve down, never seen rebuild kits for them but if its just a load of o'rings inside can probably source generic kit and go from there
  16. PhilRyder
    OK, so began dismantling this morning. The top nut came undone nicely after soaking over night. However, that nut does not release the lever. You have to remove the hinge pin. No way José! No amount of “persuasion” would shift it. It’s basically a cotter pin so I ground off the ends which allowed the lever to pop off either side. The pin will need to come out for a proper repair but we will see how the inside go.
    Rubber boot off. There are two plungers inside with a cross beam which pressed by the lever. Each has a spring. Springs removed and then there is a circling which came out easily. Now, the circling would suggest that the entire inside should come out. The plungers are stuck fast. I now have it soaking to see if anything moves, I’m not holding out much hope so new one ordered :lol:
  17. PhilRyder
    Gubbins
    Jammed pivot
    Soaking released another metal ring.
    Double plungers. No movement at all at the moment so back in soak.
    With the hidden ring out it doesn’t look like the interior body does come out but the two bright circles may. I’m really only doing this for the challenge of dismantling it now. If goes back together and works then…….bonus.
  18. rubjonny
    good progress so far, but not convinced it'll go back nicely :lol:
    the new versions are nicked from the passat and have an ally body so dont corrode so badly, plus weight savings :lol:
  19. boroko
    boroko Paid Member Paid Member
    S.W. Michigan, USA
    Since the subject of rear stubs and hubs came up, I'm hoping for some clarification. I'm in the US, and I have some mk4 rear stubs, and ordered some 6n2 hubs from he UK. I thought the bearings were the same, but they are smaller than the stubs. Is there a bearing that works between the two? Not sure what I'm missing. I can measure them both if that helps, but it's 11 degrees outside right now....
    Not sure where to look to work this out.
    Thanks
  20. dodgy
    @boroko look at seat inca/mk2 caddy van items if wanting to convert to 4 stud, the mk4 stubs fit on mk2 caddy rear axle whereas the polo/mk2 golf are different bolt pattern. May not be compatible though, but it's a possibility.
    Inquisitive mind is excellent @PhilRyder , and shows us the inside of it, nice one mate.
