Cheers for all the help above everyone, its much appreciated Will try everything thats been said over this week and hopefully get it started. Thanks Jonny. I'll see if the new earths help me out, if not i'll definitely try a new starter. Im sure me and my brother have a spare one somewhere when we stripped a Mk3. Tell me about it Its sold now though
Looks like im not the only one who has come across this problem - http://www.vwgolfmk1.org.uk/modules...7&start=0&postdays=0&postorder=asc&highlight= Think i'll try a new starter and see from there
Well ive managed to pick up a spare starter on the home from a trusted source. Will give it a try once ive eaten my KFC Lets hope it works this time
This must be a big bucket of KFC Lets hope it works! If it does work you might be a little annoyed that you took the engine out for no reason
Cheers guys ^^ Guess what - http://s487.photobucket.com/albums/rr235/richymk2/?action=view¤t=21042012001.mp4 Its turning So pleased the engine is fine. But!!! it wont stay fired up and run. All 4 coilpacks are sparking, plugs are wet but it wont stay on ? Any ideas ?
Cheers mate Yep, the plugs are wet. As the PCV system hasn't been added, would this cause any issues. Ive blocked off all the un-used vacuum hoses. Im also thinking the Crankshaft position sensor may not be torqued up properly. Would this stop it from going ?
Edited lol... Yep, everything is plugged in Matt All the vacuum lines for the DV, N75 ect are there. I'll double check the crank sensor tomorrow, im sure ive read before that it these are not in properly, the engine wont fire ?
Nope. Haven't had the change to wire the diag ports in yet ? So its getting - * Spark to all 4 coils * Fuel is getting through as plugs are wet * Engine is turning over freely * Vacuum pipes are on * Intercooler and piping is fitted ..... ?
Its gonna have a load of codes, wire in the K-line then power & earth to the diagnostic port,then get them read/cleared and try it again. Well done mind :-) SO close now!
I imagine that's correct Matt, if it doesn't know where the engine is in the cycle it won't know when to fire?
check all the various lives on the different sensors, look at the maf live, lambda, N75 etc. you still have the digifant ecu relay in there right? make sure Z/1 is connected though if injectors are going that should be fine
