Starter motor problem
Discussion in 'Mk4' started by Adam peachey, May 5, 2020.
  1. Adam peachey Forum Member
    Can anyone advise, my old starter motor used to start but made that noise after starting replaced with a new recon &I can hear it wirring sometimes &when I turn it off, the whirring nose slows untill it stops,is it a faulty starter??or is it a relay.?any help please, ta Adam
    unplug the square plug from the starter next time it does it, see if it stops
  3. Adam peachey Forum Member
    Thanks m8,where is the plug?? &what does it do?thanks again
    on the back of the starter motor, its power from ignition switch to tell it to turn over :)
    Adam peachey likes this.
  5. Adam peachey Forum Member
    Hi there, the only square plug i could find was on back of solenoid?is that the bit you ment?as its impossible to get out. &couldnt see nothing on the starter itself.is there a starter relay?in the fuse box, thanks Adam
  6. Adam peachey Forum Member
    Oh do you mean, disconect the start wire once started?
  7. rubjonny
    yes exactly, while the starter is stuck on making the whiny noises, unplug that connector and see if it stops ;)
  8. davidut5 Forum Member
    Romania
    It means you have 12v start command from somewhere but check anyway with a light bulb on that plug and ground, or a multimeter.
    This signal comes from ignition switch.
  9. rubjonny
    ok so either there is a short to live somewhere on that wire between the starter and the ignition switch, or the ignition switch itself is faulty. if it has an alarm installed it could be this which is playing up. next test is when the starter is playing up, unplug the ignition switch plug. if it stops, you need another ignition switch. you can test the new switch before you install it by plugging it to the loom and turning the switch with a screwdriver
  10. Adam peachey Forum Member
    Thanks again,
  11. Simon Peter Dodgson Forum Member
    I had a 1978 audi 80 that did this. Burnt out starter motors every 2 months. In the endI used to start it under the bonnet by putting a spanner across the +ve from battery to spade terminal as had no money for an ignition switch. Make sure its not in gear!
  12. rubjonny
    its possible the alarm is causing it, unplugging the ignition switch will narrow it down :)
  13. Adam peachey Forum Member
    But how will I start it,would as another member said, try,starting by using a spanner between plus and spade on starter,as he thought it was ignition,?
  14. Adam peachey Forum Member
    If I get a new switch, will my key still work?or is it the part at the bottom of ignition?
  15. rubjonny
    unplug it after the car is started and turned off, and starter is stuck on ;)
  16. Adam peachey Forum Member
    Thanks, will that give me a shock if i dont insulate the spanner?
  17. rubjonny
    ignition switch and lock isn't coded to anything, just the key chip to cluster so no headaches doing ignition lock swap if required
  18. Adam peachey Forum Member
    So the bit you change is at the bottom of ignition?so keep the same key?
  19. Adam peachey Forum Member
    Yes you were right, took the start wire of once started&it worked, put it back on &wiggled it &it was intermittent, but i noticed the alarm isn't working?is it linked to the ignition switch?many thanks Adam
  20. Adam peachey Forum Member
    Thanks, just noticed the alarm is not working, still got light flashing, but cant set it off, do you think it is the bottom of ignition switch that needs replacing?
