stub axle spacers...
Discussion in 'Chassis' started by TimE-J, Jan 28, 2010.
    Yes, left hand side and also some of the bottom.
    The way to do it is to draw an intersecting line using the 4 holes you're going to use.
    Then from that centre point, draw a circle of 80.5mm* - 90mm diameter**. Take off anything outside it.
    * - drum brake stub axle backplate diameter
    ** - disc brake stub axle backplate diameter
    (either will work, even if using discs, or somewhere in between)
  2. aminder
    aminder CGTI Committee - Webmaster Staff Member Admin
    Leicester
    Cool, thanks very much for you help and advice Chris.
    /Aminder
    Will keep you posted on this. Did order a couple more for someone else, may cancel and recommend use your contact. Any details on this person? Timescales? Prices?
  3. vw_singh Events Team Paid Member
    There is only one reason I can see why there are seperate left and right parts.
    The two lower holes through which you would fit the stub axle bolts appear to have a chamfer/countersink at the bottom of the holes on one side. Again, a quick drill through would fix them. :thumbup:
    Gurds
  4. aminder
    Leicester
    WOW, eye for detail hey! I didn't even notice that [:D]
  5. vw_singh Events Team Paid Member
    You own the damn things! You tell me if I'm right though.
    Gurds
  6. aminder
    Leicester
    You are right they do have a "chamfer/countersink at the bottom of the holes on one side"
    Just checked with bolt and this does not effect the bolt being put in there so won't need to be drilled out.
    I'll line then up on both sides of axcel tonight and take some pics and give some updates tomorrow.
  7. tshirt2k
    tshirt2k Forum Junkie
    Herts
    I've got some of these waiting to be put on. (Have bothe sides) Ideally, i want to change to the later removeable disks before doing it. Having trouble finding polo stubs though.
    Dimensions updated on post 66 above
  9. aminder
    Leicester
    I got the plate working on both sides without a problem last night.
    Alterations
    Passenger Side
    Drivers Side
  10. aminder
    Leicester
    I got a wake up call from VW Parts this morning and both sides are now on back order!!!
    I seem to have seen a post this morning from my iphone which has disappeared..... :-/
  11. tshirt2k
    Herts
    Nice vice. :lol:
  12. aminder
    Leicester
    ha ha.... I'm actually looking at engineering a load more up, would you be interested :lol:
  13. Mikey C Forum Member
    Thought i'd let you know how i did mine,
    I bought some aluminium offcuts off ebay like this
    you can get various thicknesses, i actually got 20mm i think, they will do some free cuts too. If you find the right size piece and get it cut you can get two pieces supplied in the size you need. Otherwise a normal jigsaw will cut it. Then i got a 11mm drill and drilled the 4 holes in each. Job done!
    No need for steel in this application, just adds unsprung weight.
    For the bolts i got some hex head 10.9 bolts again off ebay
    been on the car for a while now and done quite a few trackdays, no problems
    Mike
  14. Dclarke Forum Member
    This is how the Berg Cup racers do it. A bit extreme but you get the idea. Looks lovely and was in my 'future plans' file so liking this thread a lot:thumbup:
  15. fthaimike Forum Addict
    In fairness, whilst the Roma car isn't a Berg Cup competitor, it's done the same way as some Berg racers. The others are done via wheel offsets.
    It doesn't matter which way it's done at the back, geometry-wise.
    I wouldn't regard the Roma car as 'special' in comparison with the Berg Cup field - that's not to criticise the Roma car btw.
  17. fthaimike Forum Addict
    That's why i said not a Berg but still special as it has a lot of good stuff on it & a great drive.
  18. Dclarke Forum Member
    I stand corrected, Roma, berg Cup or otherwise - a MK1 rear suspension and hopefully of some use. [:D]
  19. rishi Forum Member
    what are these spacers made from? does anyone know the measurements and what size holes need drilling where? i want to get a set made
    Made in the Nertherlands, one offs. Search on Roma Golf - there's a thread.
    No technical data other than what can be easily assumed.
