Nevada beige 450bhp syncro
Discussion in 'Members Gallery' started by notenoughtime, Nov 22, 2016.
  1. notenoughtime
    Essex
    Just bought a floor mounted pedal box with wilwood master cylinders etc will be good to get a seating position sorted early on
  2. 1.8T_mk2
    1.8T_mk2 Paid Member Paid Member
    Hertfordshire
    You didn't waste any time! lol Good to see it being put to good use and not collecting dust hanging on my wall. :thumbup:
    Which pedal box did you go for?
    I'm probably going to go down the chassis engine mount route for this same reason. :thumbup:
    Just means a lot more fab work though :(
  3. notenoughtime
    Essex
    Ordered some extra saddle clamps and some extra roll cage tube, going to add some extra door bars in, b pillar to tunnel cross brace, dash bar, extra diagonal on rear section and harness bar with harness fittings welded in
    Sorry no pics yet! I've got to clear the car out as usual it ends up with all the bits I keep buying for it in it!
    Just a genieric pedal box Neil I'll see how I get on! Trying to build on a budget if that's possible! Lol
    1.8T_mk2 likes this.
  4. notenoughtime
    Essex
    I doubt there will be any more updates till the new year now guys! Have a great Christmas and a happy new year!
  5. notenoughtime
    Essex
    Seat mounts arrived today which means seats can be mounted along with pedal box, I may move the steering wheel down a touch to suit
  6. notenoughtime
    Essex
    Purchased a few bits
    Fuel tank and lines for the spare wheel well, not sure how far it will get me though!
  7. GAD
    gad Forum Member
    Is that an Arduino Uno ?
    What are your plans with that mate ?
    D.
  8. notenoughtime
    Essex
    To control the stepper motor in the rear diff to bias the power to it with some help with a few very helpful people on here obviously!
    1.8T_mk2 and Nige like this.
  9. notenoughtime
    Essex
    Steel arrived to day so can get on with adding a few bits to the rollcage and steel arrived to make the seats mounting points in between tunnel and inner sill
  10. notenoughtime
    Essex
    Cleared most of the crap out of the inside and started on the seat mounts
    Measured up several times with blocks of wood under the seat mount, was bit of a pain with the cage in with door bar but it's all got to fit in! Inc me! Lol
    Thought I'd got it in straight first if all but put the seat in and it was all over the place, so cut the tacks out and tried again
    I then made some brackets to weld on
    Mounts on the seats have elongated holes so no need for floating captive nuts
    All tacked in place just need to do a final check before seam welding it all in
    Had to go and look st a job so that was all my progress this afternoon unfortunately but now I've got the bits cut it shouldn't take to long
  11. Nicko Forum Member
    South Bucks
    Looking good
    notenoughtime likes this.
  12. notenoughtime
    Essex
    Tank and pipes arrived Thursday but tank is a bit small might get about 40 miles I reckon without refilling!
    But for 100 I got all the goodridge fittings inc
    One alone is 55 new, will get me up and running and prob will make a bespoke one now
  13. ThatDaveGuy
    ThatDaveGuy New Member
    awesome build!
  14. notenoughtime
    Essex
    Seat in place
  15. 1.8T_mk2
    Hertfordshire
    Looking good mate :thumbup:
  16. notenoughtime
    Essex
    Cheers Neil
    All the little bits take time as you know!
    Don't think my pedal box is going to fit as cylinders face forward and I don't think the room is there! Need one similar to yours
  17. Nicko Forum Member
    South Bucks
    That's what i'm concerned about with mine - might need to sell and get a front cylinder one
    Enjoying the progress on yours
  18. notenoughtime
    Essex
    Don't think I'll be happy with it the way it is!
    Thanks seems a bit slow TBH
  19. 1.8T_mk2
    Hertfordshire
    Yeah it's all those little bits that use up the most amounts of time and leave you with hardly anything to show for all your hard work.
    Ah that sucks. There is room under the floor to cut a wedge into the floor / bulkhead but it does mean cutting into the chassis leg section.
    I did notice you've got a lot of room behind your seat though. Could always move the seat back and extend / move the steering column maybe??
    Would mean undoing all the work put into fitting the seat fixings though [8(]
  20. notenoughtime
    Essex
    I have thought about moving the seat back but at 5ft nothing I need to see out of the car! Think it will cause more issues
    Seat frames are only tacked in just in case plans change (probably)
    I'm hoping I can get on with plenty on Saturday as not planning on doing any customer work then!
