Got the haldex in place and started tacking the mounts in place, waiting on some more 3mm plate to arrive to box it all off
Once the Haldex plates are welded in I'll blast the beam and arms and send that off to powder Coaters Need to find some Caliper carriers for the rear beam
Where did you buy the Haldex plates from they seem to be expensive for what they are a bit of bent plate
No updates from the weekend unfortunately might see if I can do a couple of late nights to get the cage and haldex finished
I took an identical photo at Autosport too. Let us know how you get on with it - is the throw adjustable?
What sort of post is that for those of us eagerly awaiting updates? That would only be acceptable if you were updating your other (red) MK2.
Rear brake adapters ordered for 280mm front discs to fit on the rear Not sure what brakes to use up front? 305mm seat Leon or 323mm or 325 with bells etc
Original rear drum 239mm discs fitted a bit lost behind the 16s will be much better with the 280's Wheels will be refurbed at some point!
Trying to lol Not yet planning on fitting it Monday when I'm sorting the last bits of the roll cage Need to source some rear shocks but got plenty to get on with still
