16v on bike carbs, they're on at last... P5
Discussion in 'Throttle bodies & non-OEM ECUs' started by Jolfa, Jan 14, 2008.
  1. Jolfa
    Jolfa Forum Junkie
    Queenstown - New Zealand
    Right, I am a total novice so bare with me... I'm looking to put bike carbs on my 6a so
    Which carbs are going to be best?
    Would I need to modify the carbs/jets at all, if so, details?
    I intend to just chop up a standard 16v manifold, block the injector holes and join the carbs to it with samco, can you see a problem here?
    I gather I can use the fuel pump from the same bike, true?
    What about the pumps already on the car?! Do these stay??
    Could I just get some kind of pressure regulator rather than another pump?
    Do I need another pump at all, or will the standard ones do the job..?
    Do I need to worry about anything plugged into my K-Jet or can I litterally just bin the lot and leave the wires unplugged?
    Anything I've not accounted for?
    Ta!
  2. drunkenalan Paid Member Paid Member
    Leicester
    you will need to reduce fuel pressure down to about 4 -6 psi for a carb setup.
    the GSXR carbs are popular and flow well, try and get some from a R6 or the R1 altho any of the racing type bikes will do, i wouldnt buy anything from a bike smaller than 600cc tho.
    I am going to be using samco' to connect my ITB's so i hope there isnt any problems
  3. Admin Guest
    Speaking from experiance here, keep the samco lengths short. I tried to extend the length from the manifold to ITB by using a larger length of samco. All it did was collapse when at idle - the vacuum was that strong. [:$] :lol:
    Thinking about it now it seems so obvious.
  4. Gareth83 Forum Junkie
    Wales
    This will be interesting to follow....
    Could you keep us updated on your plans/costs incurred etc.
    How much do you foresse this project costing???
  5. Jolfa
    Jolfa Forum Junkie
    Thanks fella's keep the answers coming (particularly about the pumps..)
    Will try and keep this as comprehensive as poss and maybe make it into the FAQ's? :)
    Not planning to spend much at all, unless I need anything else, I'm thinking sub 100... [8D]
  6. Admin Guest
    You will need to keep the KR ECU and wiring for the spark map.
  7. drunkenalan Paid Member Paid Member
    Leicester
    you could probably convert your car to the carb'd golf fuel pump setup, for little money, plenty of driver being converted to GTI spec system.
    or as you mentioned use the bikes pump.
  8. prof Forum Addict
    Suffragette City
    guys you can get "vacuum" hose which does not collaps under...er...vacuum
  9. Gareth83 Forum Junkie
    Wales
    just use a fuel pressure regulator surely? Cheaper and easier to fit??
  10. rubjonny
    Unless you call cutting a big hole in the front of the block and fitting an 8v intermediate shaft, oil pump and dizzy 'easy' I doubt you would want to try this :lol:
  11. Jolfa
    Jolfa Forum Junkie
    Ok, so I could use my standard 16v pumps, with some kind of regulator? Where can I get said regulator, and how much?
    I really am totally clueless here, I'm gonna need every detail possible
    I figured I'd need the ECU, is that all I'd need to keep? What about all the crap plugged into the airbox/inlet mani area nothing important there?
    What about modifying the carbs themselves? Any details on that, or could I just plug and play..?
  12. rubjonny
    the ecu + loom is all you need, everything else can go, fuel lines to injectors, airbox etc will not be needed anymore.
  13. prof Forum Addict
    Suffragette City
    16v pump is way too much, a regulator that knocks it down to 3-5psi would probably just heat the fuel up
  14. speedygti8v
    speedygti8v Forum Member
    market harborough, leicestershire
    i am going to be starting this conversion on my mk2 abf at the of the month using cv40's off a kwak zx9r i am using a facet red top pump and a filterking regulator. i also planned to do the same as you using a modified standard inlet manifold but i'll have to space my carbs out
  15. prof Forum Addict
    Suffragette City
    you keeping the ecu for sparks?
  16. Brookster
    M1 J40
  17. drunkenalan Paid Member Paid Member
    Leicester
    looks like a good idea, shame they dont do a manifold for the 8v / K7 conversion (Throttle bodies rather than carbs), altho i would want to be respacing the TB's as they come with a TPS so i wont have to mess about setting the TPS up, i hope!
  18. MrDubmeister Forum Member
    Northampton in a village in the middle of nowhere
    Im wanting to do this to my 2l 8v engine sat in the garage, had a change of plans and this might be exactly what im looking for.
  19. Tristan
    we did it in a Mk2 Escort , with a Zetec... used a Facet RedTop , with a Filter King Regulator , the main jets will need resizing , we went from 120 mains to 180s , on CBR900 Carbs on a 2.0l . We also changed the low end jets , from 0.40 to 0.42 . Experiment first with micro drills , then buy jets the size you want .
  20. Jolfa
    Jolfa Forum Junkie
    Right, so, just a simple answer then
    Do I need the pump from the same bike?
    If so do the pumps already on the car stay or go?
    If not, where can I get a suitable regulator and roughly how much, and will it do the job safely/adiquately?
