16v on bike carbs, they're on at last... P5
Discussion in 'Throttle bodies & non-OEM ECUs' started by Jolfa, Jan 14, 2008.
  1. barny Forum Member
    Lost in Glos
    Heres a pic of mine! No where done and still considering flogging it all as the injection/wiring etc is way above my little brains knowledge !
  2. sambo Paid Member Paid Member
    There is few pics of my set up i used to have, not carbs tho but throttle bodies of mv agusta
    I'v used modified original inlet manifold
    Just bought a valver corrado so they may be making a come back!:)
    Love the sound of them
  3. sjm66 Forum Member
    Kristiansund Norway
    looks like some good set-ups. Gonna be some nice induction noise on the roads this spring:) Here's a question....as you know I'm fitting R1 carbs to a KR engine..... which side of the carbs is the fuel in-let ?[:$] I'm asking this because the R1 carbs have a connection on both sides. Next question ......if its the left side whats the right connection for and if its the right.... Whats the left for.[:s]
    Steve
  4. barny Forum Member
    Lost in Glos
    I'd imagine feed and return, do the carbs have a pipe connecting all the carbs to each other so the fuel will flow inot the left hand one and work its way across for instance and then the right hand one will have a restricted return ?
  5. sjm66 Forum Member
    Kristiansund Norway
    Still not sure about all the connections but worked out from looking at pictures posted on here that the supply goes to a connection at the bottom of the carbs. Have had it running so I guess that was right.
    here's a link a small vid
    http://s65.photobucket.com/albums/h223/Tjabgolf/?action=view&current=tzecaddy.flv
    still to sort the exhaust but things look good
    S
  6. John West Bear Forum Member
    Shoebury
    Looks great - I'm going to be doing something similar in the future hopefully - Just starting to collect parts at the moment. What did you need to get you that far?
    Any chance you could E-mail me the Video as well?
    :clap:
  7. sjm66 Forum Member
    Kristiansund Norway
    mine was a total KR16v install so it was just about everything.
    1800 KR engine, complete with wiring loom and ECU
    5 speed mk2 gti box.... all new seals
    complete sachs clutch
    new timing belt
    100mm drive shafts.... new CV's on one side
    5 speed gear linkages ..... new bushes
    5 speed gearbox mount
    new rear and drivers side engine mount inserts
    new oil pump
    new oil cooler
    new water pump
    Ashley 4 into 1 exhaust manifold
    custom inlet manifold
    R1 carbs
    R1 fuel pump
    Silicon hose kit
    new radiator
    2 speed fan
    etc etc...... probably plenty more.
    The video was taken by a mate of mine so I don't have access to it at the momment. Plus it was taken in HD and he had a lot of problems actually getting photobucket to accept it so Emailing it could be a problem too. Sorry.
    Got stacks of help with this from the Caddy forum so if you search for PROJECT KR2008 you can tap into that info.
    S
  8. dubdad New Member
    im doing a caddy 2.0 ABF project at he mo:)
    just got my carbs & manifold back from BB's( ZX9R)
    i'll be using a stand alone H&H ignition & r1 pump,
    but i've not sussed out what i'm going to do about the water inlet
  9. Mike_H Forum Addict
    @ Jamez - What are you using for bungs in there? Looks like you found a big bolt to fit - any idea what size it is?
    Did you have to do any machining on the outside of the manifold to get the hose to seal properly?
  10. rubjonny
    I've heard gearbox drain plugs fit in the injector holes nicely, but I've not tried it meself!
  11. Gareth83 Forum Junkie
    Wales
    I've heard 1p pieces work
  12. Lhasa2008 CGTI Regional Host
    East Yorkshire
    Yep. I can confirm a gearbox drain plug fits. :)
    VW Part Number WHT001937 1.45+VAT each :thumbup:
    (was VW Part Number 111 301 127E)
  13. moorin Forum Member
    what happens to the igntion and ecu if fitting then to an efi engine? do you just get rid of the injections system fit carbs (obviously with the right fuel reg and filter and throttle/choke cable and manifold) block up the injector holes and it just runs or do you need megasquirt or something? thanks
  14. rubjonny
    the 16v ignition controller doesnt handle fueling at all so you can just keep the ignition system as is, megasquirt is also another route you can take or megajolt etc.
  15. moorin Forum Member
    so once you've got rid of the injection stuff and fitted the carbs and stuff the car will just run and respond to the carbs?
  16. rubjonny
    yeah you just fiddle with the fueling till it starts and away you go :)
    the 16v ignition controler just takes a temp sensor input, vacuum, dizzy position and works out the ign advance from that.
  17. moorin Forum Member
    orite i never new it was that easy.
  18. Jolfa
    Jolfa Forum Junkie
    Queenstown - New Zealand
    They surely do!
    I've got manifold, ZX9R carbs, just need a pump!
  19. benlg81 Forum Member
    hi jolfa
    how is this going? is there any pics as i am planning to do this to my 16v as well
  20. benlg81 Forum Member
    hi jamez
    i take it this is a standard 16v manifold was it easy to cut down? what did you use grinder saw etc?
    also what have you used to bung the holes? welded threaded in etc?
    looks perfect
    cheers
    ben
