20v APY Mk2 Garrett GT28RS.
Discussion in 'Members Gallery' started by frenno, Nov 27, 2009.
  1. frenno
    frenno Forum Member
    Folkestone
    Here are some pics of my ongoing mk2 1.8t conversion - :thumbup:
    I have so far collected most of the bits required including -
    1.8T APY engine from Audi S3
    Corrado G60 CBA 02A box
    New LUK VR6 clutch
    Corrado G60 flywheel
    G60 front callipers
    Corrado hydro pedal box master and slave cylinders
    020 > 02A adaptor plate
    cheapo coilovers (jamex)
    15" G60 steel wheels for the garage
    16" Porsche Design 90's polished for shows
    16" Diamond Cut 928's for Summer
    15" TeleDails with Dunlop Slicks for 1/4's
    New G60 top mounts
    Custom intercooler
    Vibra technics engine, gearbox and wishbone bushes
    lightweight pulley set
    02A shifter
    280mm grooved/drilled front discs
    Grooved/drilled rear discs
    Garett Gt28RS Turbo
    JBS underslung manifold
    DBW pedal
    16v k-jet fuel pump
    Corrado VR6 radiator
    twin slimline fans
    15 row oil cooler
    Cv boots, bearings, belts, vag bolts and various other small bits
    New spot lamps and red grille surround sticker
    First came a 1990 MK2 8v GTI bought as a cheap run about to get to work but within days of it arriving my plans changed....
    [​IMG][​IMG]
    4 hours later it was back in the garage minus the tired 8v Engine
    This was the reason for my change of plans a cheap Cat B Audi S3 already re-mapped to 280bhp
    [​IMG][​IMG]:o:o:):o:o:thumbup::)
  2. 1990
    1990 Paid Member Paid Member
    Rochdale, Lancs
    Cool, the S3 should give you some serious cash back.
  3. frenno
    frenno Forum Member
    Folkestone
    I stripped the S3 of all the bits I didn't need and sold them on ebay which paid for the Mk2 and of course left me with the 20vT lump happy days :)
  4. PhatVR6 Forum Junkie
    Do you still have the T5? awesome piece of kit that.
  5. frenno
    frenno Forum Member
    Folkestone
    Left with the engine I fitted a new water pump (with metal impeller) the plastic one was cracked when we got it off! new belts and lightened pulleys are going on and you can see the corrado G60 flywheel fitted
    Shortly after I found the K04 exhaust housing is cracked! and rather than replacing it with another K04 I decided on upgrading it to a Garrett GT28RS.
    Also the subframe, ARB and wishbones have been sandblasted and powder coated here they are fitted with vibra technics engine mounts gearbox mount and main wishbone bushes I also replaced all the remaining bushes with poly ones.
  6. frenno
    frenno Forum Member
    Folkestone
    Thanks, yeah still got the T5 its being featured in camper and commercial magazine over the winter and when the Golf is done it will have to go :(
  7. frenno
    frenno Forum Member
    Folkestone
    I got a cheap set of jamex coilovers we will see what they are like but I didn't want to spend more than the car cost, on just the suspension! [​IMG][/IMG][​IMG]
  8. Vento Mike Forum Junkie
    Exmouth
    Throw the interior loom away for a start! I'd even ditch the relay plate but some like to keep it as its an easy way of distrubuting the feeds from the fuel pump relay..... (thats if your gonna have the immobiliser taken off)
    Good work so far, that s3 looked quite nice on those rs4 wheels!
  9. RIP-MK3 Forum Addict
    sunbury on thames
    that loom [:s] just looking at it scares me!!! should be a right piece of kit when finished!!
  10. frenno
    frenno Forum Member
    Folkestone
    I'm now taking Vento Mike's advice and getting the immobiliser removed from the ECU. So I can now ditch the horrible mess that is interior loom and s3 clocks and keep everything a lot more OEM
  11. Vento Mike Forum Junkie
    Exmouth
    Yes!
    Might be worth keeping the relay plate for the fuel pump relay and maybe to tidy it up in the engine bay a bit move the secondry air pump relay (you'll need the relay for ease even if you don't use the pump) and ecu control relay into the cabin.
  12. frenno
    frenno Forum Member
    Folkestone
    I've been looking at a tacho converter box to run the mk2 clocks but being a DBW engine wont the ECU need a speed input? so what can I do to get round this run mk3 clocks?
  13. phatphil Forum Member
    i am thinking of doing the same conversion to my vehicle so it will be interesting to see how you get on
  14. Vento Mike Forum Junkie
    Exmouth
    you can run the mk2 rev counter no problem...just one wire from the ecu...it's the speedo that you will be struggling with as the ecu needs the vehicle speed sensor in the grearbox....or run mk3 clocks yeah but never look/fit 100% in a mk2.
  15. frenno
    frenno Forum Member
    Folkestone
    I removed the Mk2's engine loom and clocks today, sprayed the front panel and G60 hubs I also got the turbo and manifold off, would it be worth anything even though its cracked? The MK2 and S3 looms and the mk2 clocks are off to Andyout to be modified :thumbup:
  16. challice Forum Member
    wiltshire
    cool cool, nice work...:thumbup:
  17. frenno
    frenno Forum Member
    Folkestone
    Test fitted the turbo to measure for pipe work.
    [​IMG][/IMG]
  18. MUSH Forum Member
    cant remember....?
    Good choice, andys a top bloke and did mine.
    like how this thread is going. id be thinking of an lsd install, reckon youll need it to put that power down!!
  19. chong New Member
    HOVE
    Frenno, I'm currently doing a similar conversion in hangleton ( in the process of moving it all to a friends garage in lancing tho ). Whereabouts in brighton are you ?
    I'm using remapped OEM ECU also, i can't remember how i've got the speedo feed for the ecu ( it's freshly painted bare shell right now) but i'll go check later today if you're still looking mate
    barry
  20. frenno
    frenno Forum Member
    Folkestone
    Yeah Im on the look out for a LSD, price is putting me off a new one but I guess its not the type of thing to come up 2nd hand very often?
