c2 1.8t
Discussion in 'Members Gallery' started by welly24, Jun 15, 2016.
  1. welly24 Forum Member
    sutton in ashfield
    DSC_0062.jpg .that's better
    makes such a difference changing to white :)
  3. welly24 Forum Member
    sutton in ashfield
    yes its a lot better I did get the proper led's off ebay ,easy job instead of taking them out of a torch or something like ive seen on youtube and the are very cheap as well,i tried a few different colours purple ,ice blue they look good,orange red but decided on the bright white
    Sirguydo likes this.
  4. welly24 Forum Member
    sutton in ashfield
  5. welly24 Forum Member
    sutton in ashfield
    started out as a AUM engine from a mk4 golf put the audi bam engine rods,pistons,head ,injectors, k04 023turbo and manifold,and all the other bits and a mapped audi tt 225 ecu with a stage 3 map
  6. welly24 Forum Member
    sutton in ashfield
    well it different
  7. rubjonny
    you can say that again :lol:
  8. welly24 Forum Member
    sutton in ashfield
    got a bit of a weird one ,I always keep the tank half full and I filled it up last week and the fuel gauge wet to empty so I did a few more miles and it suddenly changed to 3/4 and the low fuel warning sign cam on and stayed on,checked the gauge with vcds and the readings are correct,still got the refuel sign on,any ideas,thanks
  9. rubjonny
    can only think the clocks have gone, since readings in VCDS are correct? maybe unplug the cluster for 30 seconds or so see if they reset
  10. welly24 Forum Member
    sutton in ashfield
    unplugged the clocks for 5mins working fine now thanks
  11. rubjonny
    nice cheap fix then :thumbup:
  12. welly24 Forum Member
    sutton in ashfield
    was thinking of fitting a dsg gearbox which one is the best one ,and do you have a wiring diagram for it
  13. Toyotec
    WOW George.
    Common one would be a DQ250. However there will be a bit more required to get it to work with an engine ECU that is a generation older than the gear box module.
    I know not to doubt your skills though.
  14. rubjonny
    I'm no expert on the various DSG boxes, but once you find one I can get you a diagram no problem :thumbup:
  15. Toyotec
    ^^The diagram is not a problem. Plenty of us have those. It is the integration of the system to work with an old engine controller (ME7).
  16. m1keh Forum Member
  17. welly24 Forum Member
    sutton in ashfield
    brill guys I need the gearbox pinouts for the connector on the dq250 if you have them as this is the gearbox I think I will use just need the engine driveplate as well
  18. welly24 Forum Member
    sutton in ashfield
    do they make a cover for the 1.8t coil wiring,im using the 2.0tfsi one,yes I need a manifold it cracked so im back to standard one[​IMG]
  19. welly24 Forum Member
    sutton in ashfield
  20. welly24 Forum Member
    sutton in ashfield
