c2 1.8t
Discussion in 'Members Gallery' started by welly24, Jun 15, 2016.
  1. Suicide-racer Forum Member
    This looks an interesting build.
    Cheers John
  2. welly24 Forum Member
    sutton in ashfield
    Sirguydo and Toyotec like this.
  3. rubjonny
    looks ace :)
  4. Toyotec
    What a beauty George!
    welly24 likes this.
  5. MUSHY 16V
    aberdeen
    Looks almost factory :thumbup:
    how did you get on with the fuel gauge ?
  6. welly24 Forum Member
    sutton in ashfield
    reset the float height the adjusted it with vcds 2 gallon left when the light pops on ,its a bit thirsty and a small tank so have to keep stopping to fill up,gives me a break.oh and thanks to you guys for all your help and input I don't think I would have finished it without your help and advice you kept me going when I was at a loss
  7. Tristan
    Fair play man.
  8. welly24 Forum Member
    sutton in ashfield
    so had a problem when changing gears the engine revs stay high when changing ,found out its the clutch switch has to be wired in so that's the next litte bit then its off to get mapped
  9. welly24 Forum Member
    sutton in ashfield
    well that's sorted out fitted clutch switch and wired brake light in to ecu so that's cured that ,going to put a 8inch screen in so in can moniter obd with dash commander or something
  10. welly24 Forum Member
    sutton in ashfield
    next question I'm upping the turbo need something better than k04 for more boost but want to use something that is already on a car with boost potentiall,its easier to get one off a car to mock up as I cant fit a different manifold,,, no more room at the back of the engine to bulkhead ,my t.i.p sizes would be ok for 60 to 80 mm
  11. Toyotec
    The engine has a 225ps 'K04' turbo already yes?
    And you what another more capable turbo with the same fittment as your current turbo?
  12. welly24 Forum Member
    sutton in ashfield
    no its a k04 001hybrid which is the k03 manifold ,there is very little room at the back of the engine ,I don't think the k04 manifold would fit,that why I need something that will either bolt on or maybe make a conversion plate but the turbo would have to have a round manifold inlet to the turbo to match an adapter plate to manifold,something that is already fitted to a car that I can get from the scrap yard or off ebay to mock up fitting ,don't know what size I need something with good boost reserve so I don't loose pressure at wot ,I'm open to sugestions as I will have to make a conversion plate to fit I'm looking at 350 bhp thanks
  13. welly24 Forum Member
    sutton in ashfield
    DSC_0051.jpg .moded the cowling as the sun shone on the clocks ,,,,looks pretty good to me
  14. welly24 Forum Member
    sutton in ashfield
    308 calipers.gif .its running realy well goes like a rocket could do with higher gearing as it goes throught the gears rather quickly and seems undergeared ,put bigger callipers on as well
    Sirguydo likes this.
  15. welly24 Forum Member
    sutton in ashfield
    ok latest its having a set of forged rods and a gt2871 turbo ,so heads coming off in the next couple of weeks and I have to sort out a manifold
  16. mat-mk3
    mat-mk3 Administrator Admin
    Bristol
    That didn't take long. More power!!!
  17. welly24 Forum Member
    sutton in ashfield
    yes I'm struggling to find a manifold that will fit I might have to go for the audi tt manifold and a k04 023 instead of this k04 001 which is basically a k03 hot side and k04 compressor
  18. Savagesam
    Why not go for a k03 hybrid? That way you keep the same manifold etc
  19. mat-mk3
    Bristol
    My guess is not enough power? lol
  20. welly24 Forum Member
    sutton in ashfield
    well that's that bit done new turbo, manifold,downpipe and wrapped in heat wrap and pipe work changed ,moved the battery box over for more room as the k04 was closer to the gearbox mapped at 308bhp now changed the led s in the clocks ,looks brill in white instead of the crappy blue,taking the sump off to clean it out and check oil pickup pipe and helicoil the turbo oil return bolts as there not good,oh and some 225/45/17 wheels and tyres
