Engine Oil & The ATF Trick
Discussion in 'Engines' started by dan_1987, Aug 29, 2007.
  1. G6 TEE Forum Member
    North West
    Still not got round to ATF trick yet - but will do. Stick to a good quality 10w40 oil, and you'll be fine. My favourite? Total Quartz semi synthetic
  2. dan_1987
    dan_1987 Forum Member
    I used Fuchs 15W40. My 16v was drinking the Castrol away, and smokin' like a b*tch. I'm hoping the slightly thicker oil stops this.
    I still have some ATF leftover, so I'll give it another go in 6months or so.
  3. G6 TEE Forum Member
    North West
    Castrol stuff aint what it used to be!
  4. dan_1987
    G*y. I can hear my tappets already. They're probably worn more than anything. Another dose of ATF might do then trick in 6months time.
  5. Dubber_Dan New Member
    Eastergate, W. Sussex
    Tried the ATF trick and my tappets were still noisy, so i replaced them with new ones from GSF.
    Guess what!!! Still F'ing noisy??
    What is going on? Please, anyone got any ideas.
    She's an 87 GTi - Dan
  6. Mike_H Forum Addict
    What grade of oil are you using? It might also be that your oil pump is getting a bit tired and not pumping them up properly... although new ones can take a fair bit of time to pump up (maybe 20 mins at fast idle).
  7. Dubber_Dan New Member
    I used Synta oil and the genuine vw filter.
    She's been run for at least 500 miles now so should have pumped up.
    Is it worth checking the oil pickup in the sump?
    Is there any way I can check if the pump is failing, or shall I just change it anyway?
  8. pigbladder Forum Addict
    cambridge , uk
    yeah its well worth dropping the sump and checking the pick up pipe
  9. Mike_H Forum Addict
    The Haynes has a test for clearances in the pump. Otherwise, look for signs of scoring in the gears.
  10. Dubber_Dan New Member
    Thanks guys :clap: I'll check it out
  11. ViCk Forum Member
    I kind of forgot I put ATF in my VR6 around 3 months ago, it's still in there now ! Err, time for an oil change me thinks.
  12. Pete Taylor Forum Member
    Rugby, Warwickshire
    Just preparing myself to do this now, used some of the oil flush just before the last hardcore service and didn't seem to do a fat lot, oil was proper manky! Since that i've done the water up the vac line trick a few times too any my oil is manky again after 6k with the semi synthetic oil in.
    Going to go buy some cheapo halfords ATF this week. Halfords GM6137M DII Fluid 1L auto transmission fluid for 5.99 looks like my victim, i'll run it in the car for about 200 miles as my car only does extremely short journeys all the time.
    Got another new oil filter, a cunning magnetic sump plug and some "S/S TO 521770061 S/S TO 521770061
    Fully synthetic" oil from ECP for 41.72. God knows what that oil is but it must be good! Hopefully this will stop the engine sounding like it's got a bag of spanners inside it. Looking forward to hearing the results!
  13. rubjonny
    I did this on my 160k old 8v, no adverse effects except it cleaned out all the crap holding my oil cooler together, so a week later I got oil in my coolant. Highly recoomend you change the oil cooler at the same time as dropping the oil after a flush :)
  14. Gonz Forum Member
    Brought Fuchs Titan XTR 10w/40 Oil 5 litres for 10.70 at GSF.
    With an oil filter and new sump plug washer total was 16.63 inc Vat.
    I was pretty amazed at the oil cost, synta silver was about 18 for 5L last oil change.
    My mk3 2L drinks oil, l'll see how it gets on with the Fuchs..
  15. PhatVR6 Forum Junkie
    i bought the fuchs stuff for my 24v last time, seems ok on it
    was nearly knocked off my feet by the price of the PD oil for the lupo....28 for 5 litres...plus vat.
  16. Pete Taylor Forum Member
    Rugby, Warwickshire
    I bought 2L of ATF in the end yesterday, put the first litre straight in because my oil was rather low [:$]
    I'll drain some oil, and pop the next lot in next week and run it for a couple of hundred miles
  17. Matt82
    Matt82 Forum Addict
    GTI Scene
    a litre will be fine mate.. id leave it in for a 100. keep the other litre for next time
  18. Pete Taylor Forum Member
    Rugby, Warwickshire
    Well i've just spent 40 quid on fully synthetic oil so i'm hoping it'll last a fair bit longer if i do the water trick and ATF trick a few times before the oil change
  19. Matt82
    Matt82 Forum Addict
    GTI Scene
    40 on fully synth? we only have a 4.3litre sump... what did you get?!
    i wouldnt run it with 2L of ATF in there and not for 200 miles. the ATF will be trying to clean the old oil (esp after the water trick). run a litre now for a hundred miles or so... change it, 7k later, do the ATF thing again... it wont have as much cleaning to do with the newer oil and will be able to clean the engine more.
  20. TheSecondComing Forum Addict
    Buy some 5 oil to run with the second lot of ATF? You could even not bother changing the filter, if you want to save a few .
