Engine Oil & The ATF Trick
Discussion in 'Engines' started by dan_1987, Aug 29, 2007.
  1. neil kaye Forum Junkie
    england
    forgive me for being a pest but there arnt an on the t/body
    the only place i can use is the two outlets on the servo pipe,one of which goes to the clocks and other to fei and t'd off to the vac switch and over run cut off valve,
    would i be right in saying if i use the one from the clocks,i wont have running problems as i may by takin the others off (regardless of holding it at 2.5k) also with the vacum from the manifold at 2.5k will only let the water go one way(down the manifold) and not back into the servo
    there might be a couple to the rubber boot on the tbody, I'd use one o those :)
  3. neil kaye Forum Junkie
    england
    on a K.R?
    theres only the big thick ones on the bottom boot (nr metering head) surly these are too thick and car wouldnt run wiv um off
    on some KRs yes (like mine for example), follow the pipes from the warm air flap :)
  5. G60Dub
    G60Dub Forum Member
    Angus
    Quote:
    Originally Posted by Tristan
    Know anything about women? <:
    They have 3 holes. Was that any help?
    TOTALLY PMSL - I just spat coffee all over the monitor and fell off my f3kking seat you f3kker! :lol:
    Generators and junk and broken glass under cardboard boxes... I hope no one with dyspraxia visits you! But honestly sounds interesting. :)
  6. neil kaye Forum Junkie
    england
    mmm nope,is yours the flat boot or the chunky one with squares in it,mines the old one anyhow 1988 model no vac pipes there so will hav to use the mfa one and hope i dont get water in the sevo
  7. TheSecondComing Forum Addict
    The MFA one will be fine... it's all vacuum!
  8. okman New Member
    im using 20/50 in oil in my 16v how many miles would u say is ok because im going to put ATF in my engine tomorrow
