Engine Oil & The ATF Trick
Discussion in 'Engines' started by dan_1987, Aug 29, 2007.
  1. Pete Taylor Forum Member
    Rugby, Warwickshire
    i'll run this ATF for 100 miles and do a couple of pints of water through the engine, drop the oil, leave the old oil filter on then top up with the second litre of ATF and cheapo crap oil. If I run that for another 100 miles or so then change the oil filter and put the expensive oil in I reckon. New oil is fully synthetic carlube stuff from ECP
  2. Matt82
    Matt82 Forum Addict
    GTI Scene
    kinell mate... you can get carlube fullysynth at makro for 10/5L
    im looking to try fuchs from GSF soon, no idea on price tho
  3. Pete Taylor Forum Member
    Rugby, Warwickshire
  4. altern8 Forum Junkie
    Cocos (Keeling) Islands
    Is 20/50 oil too thick for a 16v with a 1L of ATF ?
    Cheers
  5. pigbladder Forum Addict
    cambridge , uk
    is a bit on the thick side..prob be okay it you just run it for a few miles
  6. Tristan
    Whats the "water trick" ? [:s]
  7. TheSecondComing Forum Addict
  8. paultownsend Forum Member
    tried this 3 times now and iv had no luck with the noisy buggers so im going to to take the plunge and get some new tappets :(
    phoned up vw derby today, and even with discount (+vat) they work out at something like 17 each! thank god mines only an 8v!
    has anyone experiences of other brands? esp febi from avs? im just not paying that for them
  9. Gaz37 The Grouch. Paid Member
    ZZ plural 9 alpha
    BB components were selling a set of 8 hydro tappetts for 48 on Ebay a while ago.
    Might be worth doing a search although I don't know what the quality is like
  10. Sukh
    Sukh Membership Team Admin
    the driveway
    I've recently done the ATF trick on my 144k ABF using new oil and an OE filter + 0.7litre ATF.
    I was amazed at the amount of crud that came out I've still kept it so I might reuse it in another car.
    You could try reconditioning your tappets using the following guide. Might save yourself some .
    http://www.clubgti.com/forum/showthread.php?t=76499
  11. Tristan
    I was convinced you were taking the p1ss at first.... now that's a new one! Combined with the ATF trick... You probably have some kitchen method for fixing worn synchros too [:D]
    Cheers mate! I just have to try that now.
  12. G60Dub
    G60Dub Forum Member
    Angus
    Just make sure the Missus is out before employing the Kitchen Method!
  13. TheSecondComing Forum Addict
    You should see my kitchen...[:s]
    You have to navigate your way round stuff to get to the sink. I'm so used to it now I can do the drunk's two-step in the dark when I'm hammered and still get there. I dropped a glass on the floor and it broke - solution? Don't brush it up, just put a big cardboard box on top of all the broken glass so you can't stand on it. It's been like that for 2 years now, I should buy a brush.
  14. TheSecondComing Forum Addict
    Redline MTL gearbox oil normally stops them crunching... 20 of oil beats a rebuild!
  15. Tristan
    you have all the answers mate!
    Know anything about women? <:
  16. altern8 Forum Junkie
    castrol atf in halfords 7.59 with trade 5.99
  17. neil kaye Forum Junkie
    england
    i did read some of this but its just too flippin long,as anyone done this to a k.r i just wanna try it but scared of getting water in the brake servo or fei
  18. TheSecondComing Forum Addict
    Yes, I've done it to a good few, and so have lots of others. Grab a vacuum hose from the back of the throttle body and dunk it!
  19. TheSecondComing Forum Addict
    I just buy the cheapest, scummiest stuff I can find - the higher "quality" the oil, the less detergents it has in it, but more dispersants. Need to do it myself to the TDi Pishrat, but it's wet and cold and my garage is full of generators and junk...
  20. TheSecondComing Forum Addict
    They have 3 holes. Was that any help?
