and i thought mine was green when i picked it up, has this been in a swamp ? haha Body looks pretty straight, good luck pal..
Wow, that looks like it's actually been dredged up from the sea. Does it have skinny side strips on it?
If it's like most early mk2s the shell will be pretty solid under the grime! And the motor assuming it's not seized has so few electrics it should start up with little hassles. What are he plans? I'd keep it original as it's looked to have been fairly unmolested, are the p-slot centres with the car?
managed to spend about 4 hours on her over the last couple of days jobs to date quick clean all over clean cut and polish roof all wheel arch brows removed door trim removed sill stickers removed
Good effort, I really like the early ones. Looks like a nice project. I'd keep it OEM too it'll look lush when it's in its new crispy white paint.
looks like you are going to be busy, good luck, it will be good to see it returned to its former glory
wow thats some work you have! Stick with it. What are the sills and 'a' pillars like behind the front wings?
