ah, so thats how you afford it........ram raiding! really nice car this. so are you re-installing no2 (in fact can no2 be fitted? (i have no idea when it comes to these things! ))
Yes the Nitrous is going back on Direct Port which i had before with Progressive controller and 150bhp Jets 20miles to go in the morning parked in the services for the nite now in the T4 Camper Van !
Been @ Mtechautomotive all day getting the MK1 Mapped upto 4k to get it run in also the trigger wheel needs repositioning to get a better signal over 4k. Ditched the Microsquirt as it won't run wothout MAP and not running a MAP Sensor on Throttle bodies and the softaware won't let you change to Alpha N, so ok for Turbio engines but not mine. Fitted their Mtech Megasquirt V3. The bad new is i'm stuck on the A46 Near Bath the the clutch has just gone on the T4 b***ard 212miles from home .c looks like along nite home in an AA Wagon.
amazing mk1!! stunning! if you ever want to sell those golf country wheels be sure iam first on the list!
upate - arrived home this morning @ 4.30am drove the MK1 off the trailer i bet the neighbours loved that sounded at 4am !! so need to get the T4 Clutch sorted MK1 needs some minor work and them a final map doing once the Crank sensor is working correctly. The new Mtech Megasquirt V3 ECU is alot better than the Microsquirt so i'm running Megasquirt 1 software the loom had to be modified to suit but alot of items needs attention i.e. grounds for the sensor etc. http://www.mtechautomotive.co.uk/engine-management/systems/#V3_Engine_Management_System One thing i learned alot yesterday from the visit to Mtechautomotive they lads their are very very helpful and they seem to get alot of vehicles that other tuners have failed to get running Bit of a vid no power runs shown thou.
Ok ordered a new trigger wheel same as Smudge's hasn't arrived to cancelled mapping till next week. Need to get the Alloy centre piece made of think of an alternative. [/QUOTE] My current set up which will be modified. KR Pulley ABF Pulley New Trigger Wheel has arrived and the new crank sensor. Also has a new piece of Ally made for the Crank Bracket, and also got a piece of 70mm dia x 20mm deep Alloy spacer on its way for the Pulley to get a solid mount from the centre section.
New Vents put in the Bumper to assist flow to the new radiator with it mounted so low 6 x 50mm holes drilled. may have to re-mount the number plate now more central.
Revised Trigger Wheel and crank sensor set up nearly complete. Also has a new piece of Ally made for the Crank Bracket, and also got a piece of 70mm dia x 20mm deep Alloy spacer on its way for the Pulley to get a solid mount from the centre section. New trigger wheel c/w 20mm Alloy spacer ready for fitting tomorrow, could do with a new KR Pulley rather than removing the existing trigger wheel.
Think i need to spend some time this week and get the MK1 Finished been very busy with the T4 and going to show's this month. The T4 has now got the full internal camper conversion, it sits abit low due to the weight on the internal conversion, but looks good i think.
Back from a trip to France in the T4 and now making Progress at Last on the MK1 !! Fitted standard springs back on the T4 due to the extra weight of the conversion and for towing, the T4 did 1400miles , with a slight issue of some dirty veg oil blocking the filter but diesel was 88p per litre in France so filled it up and that cleared the issue. Managed to fit the new trigger wheel and Crank Sensor, much better fit. Also added two additional 50mm vent holes in the front bumper for the Radiator Air flow. Need to get the laptop plugged in and run through everything. Plugged the laptop in and try and find he problem but No success with the USB/Serial adaptor communicating with the Megasquirt. Question, when the ignition is on should the leds on the megasquirt be lit ? i know one LED is for crank signal so that won't be lit. so no spark and no LED's lit and my Multi meter is at work so will have to wait till tomorrow. just looking at getting some additional power from my 2.4D AAB Engine in my T4 Transporter without having to pull the engine out and fit a 2.5TDI Unit. Current spec - 2.4D AAB 77BHP Unit Indirect injection. Due to the Bosch mechanical Diesel injection i'm sure the addition fuelling will be straight forward. Just looking at what part list i will require. 2.5TDI Exhaust manifold c/w Turbo Ancilliaries for the turbo oil lines. Boost pipes Intercooler Exhaust down pipe and info or advise would be appreciated.
Now have two new additions to the VW Family at our house. Had to buy a new car for work so decided on an New Skoda Octavia VRS PD170 and a Fabia Sport for future wife to be. and now i have a new job i will be able to finish the MK1 2.1 16V Project at last. These aren't the cars, don't pic them up till next week but same spec and colours. Here's a Fabia Sport 1.4TDI 80 BHP Same colour and spec as Mrs's Car.
Well its been a while since an update - But here goes - The T4 2.4D Transporter is now getting Turbo'd need abit more power and after driving the VRS for a week i need more power for towing with the T4. The engine has 94k on the clock and is a good solid unit. Been on the T4 Forum for a while and here's the link for a conversion one of the T4 Lads built. http://www.angelfire.com/wv2/westfalia_california/Turbo_on_a_T4_2400D_aspirated_UK.htm i have a Volvo V70 Exhaust manifold ready to go on and a KKK 014 Turbo just need a T4 ACV Inlet manifold now and downpipe and the major components are all there then. after that its just the boost pipes and oil pipes. Here's all the part No's Manifold intake: 074 123 713 Exhaust manifold: 074 253 033 G (VW Etka catalogue only: 074 253 033 C ?) Turbocharger: 074 145 701 Gaskets of the Manifold intake: 074 129 717 Gaskets of the Exhaust manifold: 028 129 589 B (are 5 pieces) & also the gasket: 028 129 748 Here's all the other items required too. The finished project will look like this finished project but with a intercooler mounted in the front panel.
