Mk2 & 3 Golf/Ibiza/Passat subframe widths
Discussion in 'Chassis' started by A.N. Other, Aug 16, 2010.
    I've been busy measuring up narrow and wide track widths, as I reckon there's scope for a one-stop wide track thread, compiled from all the various info on this forum.
    The measurement is the centreline of both front wishbone bolts. Has anyone got Mk3 subframes lying around they can measure?
    So far:
    Mk2 Ibiza Mk2 & 3 Passat B3 & 4 Mk3 non-GTI Mk3 GTI/VR6
    60 cm 60cm 60cm 60cm ?
  2. Willber Forum Member
    Leeds
    Hi Chris,
    I can get a measurement on a MK3 GTi one as I am planning to use it instead of the rusty Mk2 one I have on my MK2 at the minute. As I understood it they are the same?
    Great idea to compile a widetrack library though as it does get a tad confusing.
  3. rubjonny
    the ibiza subframe is the same as a mk3 golf one if that helps, and all MK3 Golfs use the same subby regardless of 4 or 5 stud :)
  4. A.N. Other Banned after significant club disruption Dec 5th 2
    Hmm, that suggests that Mk2 & 3 Golfs & Ibizas 2 & 3 are all the same width between the wishbones.
    If that's the case, I can't figure out how you can get Passat shafts on a Mk2 Golf with Passat arms - they'd be too long by 5cm per side.
    If Willber can get a measurement, that would be great.
  5. rubjonny
    i agree with you there, i recal someone saying a passat vr6 driveshaft for 1 side was very difficult to get and it was specific to that model, this could explain why
    Partly why I think a one-stop wide track thread is in order - work in progress, though some guidance/checking may be needed!
  7. Willber Forum Member
    Leeds
    OK just checked from my Mk3 in the yard - centre to centre on front inner wishbone bolts (facing the front of the car) = 60cm.
    This correlates with the MK2/MK3 interchangeable subframe but with the wishbones determining the extra track width.
    Hope this helps guys.
    Ok, that's done & dusted, and we're certain from above that all Mk3s are the same.
    I think I'm going to double check that Passat measurement!
    Nice one. Off to search some older threads now.
  9. paultownsend Forum Member
    what about corrado? 8/16v vs vr6? all run different track widths
    8 & 16v Corrados are the same as a Mk2 Golf.
    Corrado VR must surely be on the same wishbone => wishbone inner bolt spacing, but the wishbones themselves + hubs are different.
  11. rubjonny
    corrado 4 pot uses same subframe as MK2 G60, which is same as MK2 except it has the extension bits behind the arb mountings and the weight on the front. uses mk2 golf wishbones, track rods, shafts and bearing carriers.
    6 pot corrado uses a MK3 Golf subframe and MK3 GTI wishbones, driveshafts, track rods and bearing carriers.
    Edit: Corraction to the above, it turns out the corrado vr6 subframe is actually lower than the MK3 subframe on the driver side by roughly 5mm :thumbup:
  12. vw_singh Events Team Paid Member
    Is it possible to add mount heights to this thread too? It is believed that the mk3 subframe sits with the engine mounts lower down, thus eliminating exhaust clearance issues when fitting tall blocks to mk2s.
    Gurds
    Hmmm, so what's the diff between a Mk2 subframe and Mk3?
  14. rubjonny
    main difference is the rear engine mount bracket, uses a completly different mount setup to mk2. it also has the metal extensions behind the arb brackets like the MK2 G60.
    I've heard conflicting reports about the engien heights thing, what we need is measurements from the subframe mounts to the chassis to the bolt holes that hold the engine mount bracket to the engine to confirm this either way
  15. Willber Forum Member
    Leeds
    Thats interesting as I am planning on using a Mk3 subframe to mount my ABF into MK2. I understand some people have issues with the engine fouling the sound deadening material on the bonnet?
  16. rubjonny
    on mine it does rub it a bit, all mk2 bits and mk2 16v/g60 mount
  17. LeftcoastTigger Paid Member Paid Member
    Rubjonny, several years ago I overheard snippets of a conversation between two local suspension guru's, the gist being VW had raised one end of the MkIII? MkIV? MkV? engine/tranny unit, and moved the entire unit a little to one side or the other - - raising one end supposedly decreased torque steer, and shifting to one side or the other improved left to right weight balance:clap:
    My ears weren't sharp enough to catch which model/s they referred to - - [:^(]
  18. LeftcoastTigger Paid Member Paid Member
    Chris, MkIII 2.0 is 60cm, confirm B3 VR6 at 70cm (edit, B3 VR6 is also 60cm, likewise B3 2.0 4-stud; it's the Passat's 4 M12 suspension cross member to frame mounting holes which are further apart compared to MkII/III)
  19. turbotommy Forum Member
    Newcastle upon tyne
    You are right ;) it was the difference between a golf mk2 & mk3 i found this out when fitting the subframes to my golf.
  20. rubjonny
    annoyingly I had a MK3 subframe in stock for a while, and was going to post detailed pics of it next to my mk2 subframe when the engine came out. but the guy i got it from needed it back desperately so I let him have it. Oh well, maybe some day someone will give us some detailed side by side pics. I'm surprised no-one has so far!
