Mk2 Golf IHI track car... Rear body work and door catches
Discussion in 'Members Gallery' started by 1.8T_mk2, Dec 9, 2009.
  1. 1.8T_mk2
    1.8T_mk2 Paid Member Paid Member
    Hertfordshire
    Head is now back on and awaiting new inlet cam, disk bells should be turning up end of Jan and have just finished making the intercooler top mounts.
    Not a massive amount of progress but better than nothing I guess.
  2. MUSH Forum Member
    cant remember....?
    I take it your running an mbc/ebc to be ale to adjust the boost matey?
  3. dUff
    dUff Administrator Admin
    Everybody Offline - looking good
    some awesome work there mate, top thread
  4. 1.8T_mk2
    Hertfordshire
    No, just using my right foot at the moment :lol: Still yet to decide on a boost controller just disconected the N75 (cuts the boost to 0.5 bar) which got me passed the noise police at snetterton. I will probably go for the Apexi when I get round to sorting it out though, seems like the best option. It was also recomended by a few other members who have a bit more knowledge on the subject than myself.
  5. 1.8T_mk2
    Hertfordshire
    Cheers fella :thumbup:
  6. 1.8T_mk2
    Hertfordshire
    Been working on a few small bits the past few weeks when time has allowed...
    Found that the front panel was cutting in to intercooler bushes so I made up two sleeves to sit between the panel and the bush...
    Started with some of this....
    Cut it into two of these...
    Shaped into these...
    Then fitted them into the front panel...
    Not sure if I like them yet but I have another idea for them that I might try when I get a chance.
    The other thing was that after changing the head from big port to small port I needed to do something with the manifold which is still big port. Rather than shell out s on a new one I had an idea....
    Started off with an old 20vt passat inlet manifold that I had laying about....
    I then cut off the flange...
    Removed most of the remaining rough cut with a pillar drill and milling bit...
    Finished off with a file...
    Marked out material to be removed...
    Removed material to leave a taper...
    And there you have it, a big port to small port manifold adapter.
    I'm hoping that this will help smooth out the air flow from the big port manifold into the small port head. Before, the air would have been slowed by the abrupt change in size but now it should be accelerated due to the taper which means I should see a little more torque.
    Thats all for now.
  7. 1.8T_mk2
    Hertfordshire
    Carried out a brief road test today, spool up is much better and the car feels a lot more driveable. Couldn't really push to hard due to the greasy conditions and the general lack of tarmac in places but I'm well pleased with the results so far. Just need to sort out some bolts for my spacer then it's off for a remap.
  8. tinydubs
    tinydubs Forum Member
    the adapter is a great idea. make more!!!
  9. 1.8T_mk2
    Hertfordshire
    If I had access to a bansaw and a mill I would. Takes way too long by hand.
    On another note, my brakes have finaly arrived back from AP which will be getting fitted this weekend along with a new middle box (so I'm below the drive-by noise limit), some V-band conectors, the bolts for the manifold spacer, some heat wrap for the down pipe and some silicone hose to plumb the O/E oil cooler back into the system to aid cooling a little bit more. I have also stripped down some old coilovers for the locking collars which, after years of abuse, are past saving on mine.
    Roll on the weekend!
  10. 1.8T_mk2
    Hertfordshire
    Bit of a hectic weekend so not much progress made but I did get a chance to finish and fit the oil cooler box and refit the OE oil cooler.
    Yet to test it on the road but it drops the oil temp from 94 down to 80 inside of 60 seconds when the fan is switched on.
    Hope to be able to get to grips with the front brakes / suspension this week if time allows.
  11. 1.8T_mk2
    Hertfordshire
    Few more jobs done so far this week...
    Booked the car in for a re-map on the 18th March.
    Also booked a slot for a trackday at Bedford Autodrome on the 28th March.
    Got around to fitting the 5 stud hubs and swapping the outter CV joints to the bigger mk3 GTI / VR ones.
    Un-seized my coilovers and changed out the front springs.
    Fitted the new bigger better brakes...
    After trying the new 17 x 8s I found that was going to have to extend the arch a little bit but not a major problem...
    Simply cut it down the middle and moved the rear section back as far I could get it, then made up a filler piece for the time being. When I have more time I will fill it in properly.
    And finally I got the new exhaust silencer ready to go on after fitting it with V-bands. Had to turn about 3mm out of the two that will fit to the silencer but it will work out a treat!
  12. danster Forum Addict
    Amazing build on the go here. :thumbup:
    Did you use the 5 stud wishbones from a mk3 Golf GTI too?
  13. 16valver Forum Member
    What size are those discs? 330's?
    Nice idea with the inlet. Not a lot of droop on that suspension...
  14. prof Forum Addict
    Suffragette City
    lush brakes
  15. 1.8T_mk2
    Hertfordshire
    Cheers mate!
    Yes, all mk3 GTI on the front suspension now.
  16. 1.8T_mk2
    Hertfordshire
    Correct, 330x28's
    Cheers bud.
    I know, I think the lack of droop is causing me problems in low speed corners tbh. As the suspension runs out of travel it lifts the inside wheel and causes the Quaife to stop working so I loose drive out of the corners. Is only a cheap FK setup at the mo and will get changed out for something a bit better in due course.
  17. 1.8T_mk2
    Hertfordshire
    I know, I can't stop looking at them :lol:
  18. richwig83 Forum Member
    Wow... i might just pop along on the 28th march and come and say hello (and take some pics) [:D]
  19. 1.8T_mk2
    Hertfordshire
    :thumbup: I'll keep an eye out for you mate!
    Been making slow but steady progress on a few bits the last few days...
    Got the exhaust nearly sorted out now, just waiting for some new hangers to turn to finish it.
    As it was...
    As it is now...
    Not very pretty but I'm hoping this will be enough to keep the noise police off my back for now.
    Also had my boost controller arrive today! [:D]
    Should help smooth things out nicely.
  20. Nige
    Nige Paid Member Paid Member
    What a great project ! Just read it all.
    I was going to ask why you failed the noise test, then saw the pic showing you only had one silencer :lol:
    Do you know what happened to the driveshaft ? I`m assuming its just the huge amount of torque you are putting through it. If so, how have you fixes them, are they uprated ones of some sort ?
