Yes had we been able to source keys, and were prepared to install the mk5 clocks. However attempts to source the keys proved a major headache, and ultimately fruitless, so the standalone route was taken. Anyhow, time to end this thread....... with a short video. Drive-by video
Great to see it finally done I'm just about to embark on mine, The rear engine mount the passat item you used what part number was it?
357 199 354, if what I've got written down is correct. Corrado G60 / 9a 16v / Passat 16v rear bracket.
Standalone system - needs switched power, connection to fuel pump relay, and connection to the rev counter via a box of tricks that converts the digital output of the MBE ecu to a coil emulating one. I essence we tore out the k-jet engine wiring, and replaced with the MBE.
