simplest way of converting a 1990 mk2 PB to VR6
Discussion in 'VR5, VR6 & Wx' started by G60KG, Jan 20, 2010.
  1. rubjonny
    the d plug would work, pin 8, 9 or 11.
    just had another look at the diagram and i think i know why it didnt work, the 2nd black wire to the D plug needs to run to an ignition live jumper block on the MK3, which is connected to D/8. The E plug itself doesnt supply any voltage :)
  2. G60KG
    G60KG Forum Member
    at work 'working'
    All done now the thing is an absolute beast loads more torque steer than the mk3. The clutch also feels fine with the cable slight problem with the throttle cable is the actual sleeve of the cable sometimes moves and the brown plastic part comes out of the bulkhead hole and gets caught when trying to go back in. The cable has been adjusted and moves the throttle fully back and forth as it should so not sure how to stop the sleeve moving.
  3. RIP-MK3 Forum Addict
    sunbury on thames
    ^^^ thats exactly why ours was cutting out, no live to transponder box. Best thing was - we had put the dash back in and had to drag it out again!!!
  4. Toyotec
    Glad to hear it is all running matey.
    Should be well nice in a lighter chassis. Fans coming off and on as required...yes?
  5. G60KG
    G60KG Forum Member
    at work 'working'
    yes fans coming on as they should - that was a nicely timed visit cheers Eddie :thumbup:
  6. Mike_H Forum Addict
    Good progress!
    When's the test drive then, or should I give it a week so you can find out if you forgot to tighten any bolts?
  7. G60KG
    G60KG Forum Member
    at work 'working'
    I will try and come and see you this week some point. My bro in law has the car in Southall at the moment and he's gone and put his foot through the wiring around the fusebox as I did not get a chance to do the final tidy up so the car currently has no power to the ignition at all :lol: sure its a quick fix though.
    I am pretty sure the bolts are ok although just remembered that I forgot to refit the little metal flap that covers up the bottom of the flywheel area [:$]
  8. Mike_H Forum Addict
    He broke it - he should fix it! It would have helped if you'd spent 2 minutes with some cable ties though!
  9. Toyotec
    Tie wrap - The enthusiasts best friend...
  10. G60KG
    G60KG Forum Member
    at work 'working'
    turns out i forgot to tighten the battery terminals [:$]
  11. Mike_H Forum Addict
    Remember that conversation about attention to detail? :lol:
